Question about Philips TSU7000 LCD Touchscreen Remote Control
Added the wrong button
I was trying to setup a new projector for my friend's dad. When I went to program the projector remote with the tsu7000, I pushed the wrong button and ended up recording over his B&K ON button. He does not have the remote for the B&K - how can I make it be the on buton for the B&K again? Also, how do I add a projector to his devices? Thank you!
  • 10,865 Answers
Need code for apex tv/dvd combo to program remote
http://www.hifi-remote.com/ofa/apex_help.shtml
To program the Apex DVD player on your Radio Shack or One For All remote, there are several steps involved. Basically you will be using the TV device code 0030 and re-mapping all the buttons. There's several steps to get wrong so I will include lots of error checking so that if you make a mistake you will know where you went wrong. Before you start, you should print off the advanced codes.PLEASE NOTE:This will only work for the AD600A model. There isn't a code in any of the current OFA/RS remotes for the newer models (ie, AD500A, AD660A, AD703A, AD800A, etc)
1. Confirm that you have TV code 0030 on your remote.
(Every remote has this code, I am including this step just for your piece of mind, by all means skip it and come back to it if you have problems).
a. Turn on your DVD player and have is displaying on the TV.
b. Press the TV button.
c. Press and hold the SETUP button (the green P button on R/S remotes), wait for two flashes.
d. Type 0030 and wait for two flashes.
e. Press the POWER button, you should see the VOLUME indicator display on the TV screen.
You have now confirmed that you have the TV code 0030.
2. Re-assign the DVD button.
(On the Cinema 7 remote you will probably want to use the DVD button, on the R/S remotes you might want to chose the AUX2 button. In this example when I refer to the DVD button, I am referring to whichever device key you have selected to control your DVD player).
a. Press and hold the SETUP button, wait for the two flashes.
b. Type 992, wait for the two flashes.
c. Press the TV button, followed by the DVD (or AUX2) button. Two flashes.
You have now re-assigned your DVD button to be a TV button, this is so we can enter the TV device code.
3. Assign the TV/0030 code.
a. Press the DVD (or AUX2) button.
b. Press and hold the SETUP button, wait for two flashes.
c. Type 0030 and wait for two flashes.
You have programmed the DVD button to TV code 0030.
4. Program the function buttons.
(You will have to program every button that you intend to use. Don't waste memory by coding buttons that you will rarely, if ever, actually use. If you don't think you will use the numeric keys, for example, don't program them. If you intend to use the volume controls from your TV or amplifier, don't program the volume controls).
I will walk you though setting the POWER button.
c. Type 994, wait for the two flashes.
d. Press and release the SETUP button. (Don't hold it this time).
e. Type 052 (this is the code for POWER).
f. Press the POWER button, wait for the two flashes.
g. Press the POWER button, your DVD player should turn off.
You have now programmed the POWER button. Repeat the steps above for all the buttons that you want to program.
5. Resetting the DVD device.
In order for "volume punch through" to work, you will need to reset the DVD device button to be a DVD button again. This is only an issue for the Cinema 7, because "volume punch through" only works on the original VCR and CBL buttons on the 15-1994, and even then it will only work with the TV's volume).
c. Press the DVD button twice. Two flashes.
You have now reset the DVD button.
6. Setting up the volume controls.
You have several choices with the volume controls. You can program them with the APEX codes, which will invoke the DVD players volume controls, you can use "volume punch through", or you can manually set the volume controls to operate the device of your choice. In this example I will assume that you want to use your stereo equipments volume controls and that the stereo is programmed to the CD device button. Please replace the CD button with the TV button in this example if you want to use your TV's volume.
d. Press the CD button, followed by two presses of the VOL UP button.
e. Wait for two flashes.
You have now programmed the DVD's volume up button to control the CD's volume up function. Repeat these steps for the volume down and mute buttons.
7. Setting up a Loophole Menu macro button.
If you have the version of the Apex that has the "Loopholes Menu", then you might want to set up a button to take you right there. It saves having to remember the secret steps. In this example I am going to put the macro on the "S4" button, but you can put it on any button you like, just remember that it will be in effect under all devices.
c. Type 995, wait for the two flashes.
d. Press the S4 button (or the button of your choice).
e. Press the following buttons in this order (the button names in paranthesis are the buttons that I suggested these Apex functions be assigned to):
STOP, STOP, SETUP (Program), STEP (Move), PREV TRK (CH Down), NEXT TRK (CH Up)
f. Press and hold the SETUP button, wait for two flashes.
It is important to hold the SETUP key until you see the two flashes in the last step. If you release it too soon, the remote will assume that you want the SETUP button to be part of the macro, which will cause some un-expected results when you try using the macro.
Hopefully you have now successfully programmed your remote to handle your Apex DVD player, now you can enjoy movies from all over the world. if you haven't already visited the un-official Apex head quarters, here's the address: www.nerd-out.com/apex.
May 15, 2015 | RCA Universal Remote Control
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Is there a way to setup my universal remote for my dell 2400mp dlp projector? if so what is the 4 digit code?
You need a learning remote as most "universal" remotes don't have the codes pre-programmed for projectors. The Logitech Harmony is worth it's weight in gold, and it looks cool, but will set you back about $100. There are cheaper learning remotes, and they may suit your purpose better, look on New Egg and Ebay.
Jul 02, 2011 | Dell 2400MP DLP Projector
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
How do you reset the Projector after installing a new lamp?
There are two common methods to reset the lamp counter on these projectors: Method 1: - Press the decrease volume button on the remote and then the increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
Jul 19, 2010 | Sharp Projector lamp Projector Lamp
Only 1 remote will work at a time
One of your remotes has reverted to an earlier technology and they will no longer work with each other. You need to purchase a new remote making sure you get the same model number. Then you will find you can program 2 that will work with each other and 1 that will not. Remove the battery from the bad remote and toss it so that it doesn't cause problems down the road.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't recieve any stations
The remote would need to reprogrammed for the other devices. It loses its programming when the batteries are replaced. There may be a model number on the back of the remote or under the battery cover. With that information you can probably find the instructions on the manufacturer's website. Or you can purchase another remote if all else fails. They're pretty inexpensive.
There's nothing the remote can do that would affect your TV unless you hit one of the buttons, possibly switching to another input. Unplug the set and let it sit a few minutes. Plug it back in and go through the initial setup again. This should bring everything back to normal for you.
If you're still having problems, please post a followup comment and I'll try to help more.
Apr 22, 2009 | RCA F36690BC 36" TV
Panasonic LCD Projector PT-L720V
Press 'menu' and 'enter' buttons at the same time.
Mar 18, 2008 | Panasonic Videoprojector PT-LM1E...
Philips TSU7000 LCD Touchscreen Remote Control Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
