Question about Sony 1GB Micro Vault Ultra Mini USB 2.0 Flash Drive 1 GB USB Portable (USM1GDVFT) Drive
Will not let me save a file and reads file permission error
My sony 1gb usb stick will not allow me to save data and reads file permission error
  • 1,029 Answers
I think for some reason there is a limit to the number of files (nb: number of files not amount of space used) that the root directory can handle. Try making folders and moving files into these to cut down on the number of root directory entries.
Posted on Apr 21, 2009
  • Starnley Johnwells
    Starnley Johnwells Apr 21, 2009
    also Check to ensure that the USB drive is not full.
    You may need to delete some content to make room - Word also creates tons of temp files in the working directory which you are saving to, so you may need to save the document to your desktop and close it, then copy the document file to your USB drive (Word automatically destroys all the temp copies it created as soon as you close the document).
I can't add files to my USB stick, it gives me read only error. I'v done running Using Registry Editor and diskpart,still the error is present. What will I do?
it is write protected which means that you cannot add anything to the usb stick
you will have to get the administrators permission to change to edit the usb stick
if you are the originator of the original entry , then go to the permissions section and change to read and write
Jun 30, 2017 | The Computers & Internet
Like where to format sony memeory stick duo?
click start click to open on my computer you should see your Usb drive E:
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Apr 16, 2012 | Sony 1GB Memory Stick PRO Duo Memory Card
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Usb stick not usable
Because its beyond 4Gb that's why its already detected as a disk drive.
You can still save your files here. Have you already tried?
If so, what is the exact error you are getting?
Aug 06, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Inability to "save" on one of my 2 memory sticks.
You have probably just filled the memory stick.  or set it to read only.  does it have a little switch on it's side?
May 20, 2009 | Advent 4211c Notebook
Cannot save to my Kingston usb
maybe your file permission is read only. Go to my computer, browse your file. Right click and choose Properties. Uncheck the Attribute
May 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How does SanDisk 2GB allow save to?
Some USB sticks have a little switch on the side of it to "lock" the data, this makes all data read only make sure yours doesn't have one or that it is in the unlocked position.
If you want to reformat the stick, plug it into the computer, go to my computer, then right click on the drive letter and go to "Format". Pick "FAT32" as the type of file system and format.
Jan 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory Stick error c:13:01
The problem is compatibility - or lack thereof. The older Sony cameras such as DSC-S50 (I have one), which used the original version of the Sony Memory Stick, can't read the new Memory Stick Pro - even with the "Duo" adapter.
I don't know all the specifics but it has to do with how the memory chip interfaces w/ the camera, how the data is transferred -- newer models of chips/cameras use a different, faster method for data transfer which the older cameras/devices can't do. Similar to "serial" vs. "USB" vs. "USB-2" issues with older computers.
So, sorry to say, but if you have a DSC-S50 camera like I do or similar older model, you're stuck w/ the standard Memory Sticks - which I have just discovered are very hard to find any more. I just finished a sweep of all major electronic stores/outlets in my area (silicon valley - where there's plenty of them), plus many web sites. And all you can find new, now, are the Pro/Duo chips, 1GB & up.
Anyway I hope this helps!
Dec 27, 2007 | Sony Cyber-Shot DSC-S50 Digital Camera
Computers & Internet Logo
244 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
