Question about Canon PIXMA MP780 All-In-One InkJet Printer
Can't change image quality
For about a week, my mp780 is stuck on "fine photo pro" when I use the auto sheet feeder. Anything I print takes forever as a result. If I switch the paper source to the cassette, everything is fine. Also with the cassette as a paper source, I can change the image quality to what I want. With the auto sheet feeder, the image quality stays at fine even if I try to change it back to normal. Thanks
  • pulsating Sep 22, 2007
    Thank you, but where would I find a stuck micro switch that detects the auto feeder in use?
  • dwahlstedt Feb 06, 2009
    rftgyhuj is my hero.  I had the same problem, and had it solved in under 30 seconds with that one simple suggestion.
The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
Posted on May 14, 2008
Hit "two-sided button" on and off - the display changed to "LTR Normal - Plain".
Posted on May 18, 2011
Change paper type as plain paper, then you can change copy quality.
Posted on Oct 02, 2007
  • 2,985 Answers
This is either a stuck micro switch or a software glitch. Easiest thing first. Remove software and reinstall. If still acking up Look for a micro switch that detects Auto sheet feeder in use.
Posted on Sep 22, 2007
  • john ash
    john ash Sep 22, 2007
    The paper cassette slot will have a small button like switch i would imagine[I don't know the actual machine- these are general imaginings]
    So some where near where it locks in there will be such a thing.
    A look at then select your printer may have a solution- failing that Canon Support.
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
use the canon software and set up fax seperately.
Aug 05, 2009 | Computers & Internet
My incoming faxes won't print. both black ink cartridges r full
Is there any message when you try to print the faxes?
If there is an "Image Quality" message, probably the printer is set up to "Copy" in "Photo" or "Fine" mode and it needs to be set to something other than "Fine" or "Photo"
Apr 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
In copy mode I can't get Image Quality to change from Fine
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Print quality stuck on fine
Did you check in the software? There should be a print quality option in your driver software.
Dec 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Photo R260 doesn't complete prints
Make sure that you have the correct paper size set in your printer settings. Incorrect size would cause the problem you describe.
Sep 17, 2008 | Epson Stylus Photo R260 InkJet Printer
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Legal paper
Legal size paper must be loaded into the automatic sheet feeder (ASF) in the rear, and the Feed Switch used to set Auto Sheet Feeder.
For printing, in the Printer Properties (or Printing Preferences) dialog box, select the Page Setup tab, and set the Paper Size to Legal.
May 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
613 people viewed this question
old marine
old marine
