Question about Philips AZ1007 Cassette/CD Boombox
Nothing works, radio, CD player. When switch is moved sounds like it will work, doesn't. Bad switch or bad cord?
When I move the on/off switch their is a clicking noise like the unit is engaging, but no sound from the radio. The CD spins the stops. I can move the switch a little to generate some power, but it usually quits. Tried moving the electrical cord from the back of the player in and out, same reaction as the switch. Even tried plugging into a different outlet, same response.
SOURCE: wont spin
cdfreeze, DVD drives spin up the platter and attempt to read from it. If the read fails, they stop spinning the drive. So, I think the problem you have is that the device won't read. DVD drives have some very small plastic pieces that can break and cause failure. They also have a read head that can get out of alignment. If you're ambitious, look at the drive and see if you can find any other damage. Don't run the drive open, though, because there is invisible laser that can blind you (there should have been a warning on the top of the drive when you opened it). I checked eBay and this DVD player sells for under $20 (including shipping), so don't spend too much time on it. Definitely let me know if you have questions or comments.
Posted on Aug 22, 2007
SOURCE: dvdr3455/37 stopped working
I had the same problem - and here is how I fixed it.
When it was booting/re-booting I ejected the disk (I needed it out anyway since I assumed the unit was dead.) After ejecting the disk it display "load" on the unit. I read in another message board that this means the unit is looking for the firmware disk. I went to http://www.usasupport.philips.com/productDocuments.html?ProductCode=DVDR3455H/37&subCat=DVD_HARDDISK_RECORDERS_SU_US_CONSUMER
I followed the instructions to make the "upgrade CD" and inserted into my DVR. My unit then powered up normally. I went ahead and upgraded the software and it did happen again (the re-boot cycle) until I entered the date/time.
HTH
Posted on Jun 05, 2008
SOURCE: won't connect to pc
YOU DON'T NEED A USB CABLE!!! Buy a cable that has a red, white tip on it and a headphone tip on the other end then plug the red, white cable infront of the boombox. Then plug the headphone tip into the back of the pc where you would plug in regular computer speakers into it.
I don't know the exact name for the wire but some portable dvd players contain them.
I never used a usb cable too much trouble.
Posted on Dec 15, 2008
SOURCE: HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Posted on Jan 29, 2009
  • 280 Answers
SOURCE: TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Posted on Apr 10, 2009
The unit will not turn on (after being moved)
Sounds like a bad cord. There are lots of cheap cords that fail easily these days.
Nov 07, 2013 | Sunpentown WC-1682 16 Bottle...
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
Radio works but face plate shows nothing
You have two possibilities. You can try cleaning the contacts on the back of the radio and on the subpanel with qtips and rubbing alcohol or a pencil eraser. If that doesn't work, you may have bad solder connections on some surface mount resistors inside of the radio. If you are good at soldering they should be on the right front of the radio, you will have to remove the cd mechanism to get to them.
Mar 14, 2012 | Kenwood KDC-MP4028 CD Player
Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
Side mirror and radio not funtioning at all toyota corolla 2001
Probably a blown fuse. Find the fuse box, (make sure car if not running, key out of ignition), open fuse box cover. The cover usually has a description of what fuse does each power task. Find the radio/ACC fuses and removing them one at a time (don't have 2 out at once), hold them up to the light and look for a broken band inside the fuse. If you find one, replace it with a new one of the same size and amperage. It is the cheapest place to start.
May 02, 2011 | Toyota Corolla Cars & Trucks
Cd player not working. CD error E25
First get a CD Lens Cleaner and try it; if not, disconnect the negative lead from your car battery for about 10 min. BUT! Unless you have the radio code make sure you car radio doesn?t have an anti-theft system; if after this few steps still nothing you have to send it to an electronics repair shop (the CD Lens is bad).
Jan 06, 2010 | Car Audio & Video
The radio works but the CD does not
Hi Could be a bad selector switch, try jiggling it back and forth to see in it works in an in between position. Possible loose power connector to the cd player or cd is faulty. Jay
Jan 21, 2008 | GPX TVB544 5 in. Portable Television
Philips AZ1007 Cassette/CD Boombox Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
