I have a virus and I need to format my pc I think I hit ctrl alt f11 but not sure can someone help
  • bethybaby90 Apr 21, 2009
    Thank you, but I dont have the orig disk.. So I guess I'm pretty much SOL... Thank you anyways...
  • Jerry May 11, 2010
    Do you have the Operating System disk? Like Windows XP or a system restore disk that came with your system?
  • 31 Answers
Hi bethybaby90, I would like to inform you that Formatting a PC is to delete all the data that currently is on your Computer and upgrade it to a newer version of an operating system or install the same operating system once again on the same computer.
The process of formatting is as follows:
1. Insert the WINDOWS XP bootable disk in the CD drive.
2. Restart your PC (if it was already running).
3. Press enter when the monitor reads PRESS ANY KEY.
4. Now comes the time to partition your drives.
5. If you want to delete any partition, press D or L(whichever is displayed on the screen).
6. Afterwards format the drive you want to install the operating system (XP) in.
7. Press ENTER.
8. The formatting will start.
9. Follow the procedures.
10.It should take around 40 minutes for the installation to finish.
11.Use windows(HAVE A GOOD TIME).
I hope this resolves your issue.
Your feedback is appreciated.
Askari :)
Posted on Apr 21, 2009
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Tip
Keyboard shortcuts for Microsoft Windows XP, Vista, 7 and Microsoft Office
Windows
Windows Key+E
This shortcut allows you to open Windows Explorer with one quick keystroke.
Alt+Tab
This allows you to easily toggle back and forth between all the windows you have open. You can also use this to switch between windows in the same program, making multitasking real easy.
Windows key+Tab
This lets you scroll the items on the taskbar, and in Vista, it starts Flip 3D for a fun graphical spin on the same idea.
Alt+F4
This shortcut is a quick way to close a window in any program without using your mouse to hit the X in the upper-right corner.
Windows Key+M
This allows you to minimize all of your open windows, leaving just the desktop left exposed. To restore the windows, hit Windows key+Shift+M. Another quick way to do this is Windows key+D, which shows your desktop; to restore, just repeat the same keystroke.
Ctrl+Drag
There are many ways to copy a file, but this just might be the easiest. All you have to do is click on the file, hold, and drag it into its desired location. This works the same as another handy shortcut, Ctrl+C.
Windows Key+U+U
This is the shortcut for quickly shutting down Windows by hitting the Windows key (don't hold it down), hitting U to reach the shutdown menu, and then hitting U again to shut down.
Windows Key+Pause
This is a quick way to get to the Systems Properties menu.
Shift+Delete
If you want to delete a file-and you don't want to deal with it later in the Recycle Bin-this is the way to go. Just be absolutely sure that this is a file you won't want back!
To bypass the Autorun when inserting a CD
Hold Shift While Inserting the CD.
Microsoft Office
Ctrl+U, Ctrl+B, Ctrl+I
Used to snap to underline, bold, and italicize without the mouse if you press Ctrl+U (underlining), Ctrl+B (bolding), or Ctrl+I (italicizing).
Shift + Arrow Keys
Holding shift and pressing one of the arrow keys will highlight text in Word (or a group of Excel cells) without the mouse, selecting in the direction the arrow points.
Ctrl+Z, Ctrl+Y
Undo an action by hitting Ctrl+Z; if you change your mind, Ctrl+Y will redo the undo.
Microsoft Office - Excel
F1
Opens a help task pane
F1 + Ctrl
Opens or closes the help window
F2
To edit the text in the active cell
F2 + Shift
To write a comment in the active cell
F2 + Alt
Opens the save as dialog box
F3 + Shift
Opens the insert dialog box
F3 + Ctrl
Opens the define name dialog box
F3 + Shift + Ctrl
Opens the create name dialog box
F4
To redo the last command
F4 + Ctrl
To close the workbook window
F4 + Alt
To close the excel program
F5
Opens the Goto dialog box
F5 + Ctrl
brings back to the first level of workbook
F6
To shift between help taskbar and the excel window
F6 + Shift
To goto the previous square in the open worksheet
F6 + Ctrl
If more than one workbook is open to switch between them
F7
To open spelling correction window
F7 + Ctrl
When workbook window is not maximised it will move the window
F8
To activate / deactivate extended mode
F9
Will calculate all the worksheets in all open workbooks
F9 + Shift
Will calculate the active worksheet
F9 + Ctrl
To Minimise the workbook window
F10
Will select the menu bar
F10 + Ctrl
To open minimised window
F11
Will create a chart using the current range
F11 + Shift
To select a new worksheet
F11 + Alt
To switch between visual basic editor and the worksheet
F11 + Alt + Shift
Opens microsoft script editor
F12
Opens save as dialog box
F12 + Shift
Saves the active workbook
F12 + Ctrl
To open the Open dialog box
F12 + Ctrl + Shift
Opens the print dialog box
on Jan 01, 2011 | Computers & Internet
Tip
WORD 2003 Shortcuts
All Caps Ctrl+Shift+A
Annotation Alt+Ctrl+M
App Maximize Alt+F10
App Restore Alt+F5
Apply Heading1 Alt+Ctrl+1
Apply Heading2 Alt+Ctrl+2
Apply Heading3 Alt+Ctrl+3
Apply List Bullet Ctrl+Shift+L
Auto Format Alt+Ctrl+K
Auto Text F3
Auto Text Alt+Ctrl+V
Bold Ctrl+B
Bold Ctrl+Shift+B
Bookmark Ctrl+Shift+F5
Browse Next Ctrl+Page Down
Browse Prev Ctrl+Page Up
Browse Sel Alt+Ctrl+Home
Cancel Esc
Center Para Ctrl+E
Change Case Shift+F3
Char Left Left
Char Left Extend Shift+Left
Char Right Right
Char Right Extend Shift+Right
Clear Del
Close or Exit Alt+F4
Close Pane Alt+Shift+C
Column Break Ctrl+Shift+Return
Column Select Ctrl+Shift+F8
Copy Ctrl+C
Copy Ctrl+Insert
Copy Format Ctrl+Shift+C
Copy Text Shift+F2
Create Auto Text Alt+F3
Customize Add Menu Shortcut Alt+Ctrl+=
Customize Keyboard Shortcut Alt+Ctrl+Num +
Customize Remove Menu Shortcut Alt+Ctrl+-
Cut Ctrl+X
Cut Shift+Del
Date Field Alt+Shift+D
Delete Back Word Ctrl+Backspace
Delete Word Ctrl+Del
Distribute Para Ctrl+Shift+J
Do Field Click Alt+Shift+F9
Doc Close Ctrl+W
Doc Close Ctrl+F4
Doc Maximize Ctrl+F10
Doc Move Ctrl+F7
Doc Restore Ctrl+F5
Doc Size Ctrl+F8
Doc Split Alt+Ctrl+S
Double Underline Ctrl+Shift+D
End of Column Alt+Page Down
End of Column Alt+Shift+Page Down
End of Doc Extend Ctrl+Shift+End
End of Document Ctrl+End
End of Line End
End of Line Extend Shift+End
End of Row Alt+End
End of Row Alt+Shift+End
End of Window Alt+Ctrl+Page Down
End of Window Extend Alt+Ctrl+Shift+Page Down
Endnote Now Alt+Ctrl+D
Extend Selection F8
Field Chars Ctrl+F9
Field Codes Alt+F9
Find Ctrl+F
Font Ctrl+D
Font Ctrl+Shift+F
Font Size Select Ctrl+Shift+P
Footnote Now Alt+Ctrl+F
Formatting Properties Shift+F1
Go Back Shift+F5
Go Back Alt+Ctrl+Z
Go To Ctrl+G
Go To F5
Grow Font Ctrl+Shift+.
Grow Font One Point Ctrl+]
Hanging Indent Ctrl+T
Header Footer Link Alt+Shift+R
Help F1
HHC Alt+Ctrl+F7
Hidden Ctrl+Shift+H
Hyperlink Ctrl+K
Indent Ctrl+M
Italic Ctrl+I
Italic Ctrl+Shift+I
Justify Para Ctrl+J
Left Para Ctrl+L
Line Down Down
Line Down Extend Shift+Down
Line Up Up
Line Up Extend Shift+Up
List Num Field Alt+Ctrl+L
Lock Fields Ctrl+3
Lock Fields Ctrl+F11
Macro Alt+F8
Mail Merge Check Alt+Shift+K
Mail Merge Edit Data Source Alt+Shift+E
Mail Merge to Doc Alt+Shift+N
Mail Merge to Printer Alt+Shift+M
Mark Citation Alt+Shift+I
Mark Index Entry Alt+Shift+X
Mark Table of Contents Entry Alt+Shift+O
Menu Mode F10
Merge Field Alt+Shift+F
Microsoft Script Editor Alt+Shift+F11
Microsoft System Info Alt+Ctrl+F1
Move Text F2
New Default Ctrl+N
Next Field F11
Next Field Alt+F1
Next Misspelling Alt+F7
Next Object Alt+Down
Next Window Ctrl+F6
Next Window Alt+F6
Normal Alt+Ctrl+N
Normal Style Ctrl+Shift+N
Normal Style Alt+Shift+Clear (Num 5)
Open Ctrl+O
Open Ctrl+F12
Open Alt+Ctrl+F2
Open or Close Up Para Ctrl+0
Other Pane F6
Other Pane Shift+F6
Outline Alt+Ctrl+O
Outline Collapse Alt+Shift+-
Outline Collapse Alt+Shift+Num -
Outline Demote Alt+Shift+Right
Outline Expand Alt+Shift+=
Outline Expand Alt+Shift+Num +
Outline Move Down Alt+Shift+Down
Outline Move Up Alt+Shift+Up
Outline Promote Alt+Shift+Left
Outline Show First Line Alt+Shift+L
Page Alt+Ctrl+P
Page Break Ctrl+Return
Page Down Page Down
Page Down Extend Shift+Page Down
Page Field Alt+Shift+P
Page Up Page Up
Page Up Extend Shift+Page Up
Para Down Ctrl+Down
Para Down Extend Ctrl+Shift+Down
Para Up Ctrl+Up
Para Up Extend Ctrl+Shift+Up
Paste Ctrl+V
Paste Insert
Paste Format Ctrl+Shift+V
Prev Field Shift+F11
Prev Field Alt+Shift+F1
Prev Object Alt+Up
Prev Window Ctrl+Shift+F6
Prev Window Alt+Shift+F6
Print Ctrl+P
Print Ctrl+Shift+F12
Print Preview Ctrl+F2
Print Preview Alt+Ctrl+I
Proofing F7
Redo Alt+Shift+Backspace
Redo or Repeat Ctrl+Y
Redo or Repeat F4
Redo or Repeat Alt+Return
Repeat Find Shift+F4
Repeat Find Alt+Ctrl+Y
Replace Ctrl+H
Research Lookup Ctrl+Shift+O
Reset Char Ctrl+Space
Reset Char Ctrl+Shift+Z
Reset Para Ctrl+Q
Revision Marks Toggle Ctrl+Shift+E
Right Para Ctrl+R
Save Ctrl+S
Save Shift+F12
Save Alt+Shift+F2
Save As F12
Select All Ctrl+A
Select All Ctrl+Clear (Num 5)
Select All Ctrl+Num 5
Select Table Alt+Clear (Num 5)
Show All Ctrl+Shift+8
Show All Headings Alt+Shift+A
Show Heading1 Alt+Shift+1
Show Heading2 Alt+Shift+2
Show Heading3 Alt+Shift+3
Show Heading4 Alt+Shift+4
Show Heading5 Alt+Shift+5
Show Heading6 Alt+Shift+6
Show Heading7 Alt+Shift+7
Show Heading8 Alt+Shift+8
Show Heading9 Alt+Shift+9
Shrink Font Ctrl+Shift+,
Shrink Font One Point Ctrl+[
Shrink Selection Shift+F8
Small Caps Ctrl+Shift+K
Space Para1 (single spacing) Ctrl+1
Space Para15 (one-and-a-half line spacing) Ctrl+5
Space Para2 (double spacing) Ctrl+2
Spike Ctrl+Shift+F3
Spike Ctrl+F3
Start of Column Alt+Page Up
Start of Column Alt+Shift+Page Up
Start of Doc Extend Ctrl+Shift+Home
Start of Document Ctrl+Home
Start of Line Home
Start of Line Extend Shift+Home
Start of Row Alt+Home
Start of Row Alt+Shift+Home
Start of Window Alt+Ctrl+Page Up
Start of Window Extend Alt+Ctrl+Shift+Page Up
Style Ctrl+Shift+S
Style Separator Alt+Ctrl+Return
Subscript Ctrl+=
Superscript Ctrl+Shift+=
Symbol Font Ctrl+Shift+Q
Task Pane Ctrl+F1
Thesaurus RR Shift+F7
Time Field Alt+Shift+T
Toggle Character Code Alt+X
Toggle Field Display Shift+F9
Toggle Master Subdocs Ctrl+\
Toggle XMLTag View Ctrl+Shift+X
Translate Pane Alt+Shift+F7
Un Hang Ctrl+Shift+T
Un Indent Ctrl+Shift+M
Underline Ctrl+U
Underline Ctrl+Shift+U
Undo Ctrl+Z
Undo Alt+Backspace
Unlink Fields Ctrl+6
Unlink Fields Ctrl+Shift+F9
Unlock Fields Ctrl+4
Unlock Fields Ctrl+Shift+F11
Update Auto Format Alt+Ctrl+U
Update Fields F9
Update Fields Alt+Shift+U
Update Source Ctrl+Shift+F7
VBCode Alt+F11
Web Go Back Alt+Left
Web Go Forward Alt+Right
Word Count List Ctrl+Shift+G
Word Count Recount Ctrl+Shift+R
Word Left Ctrl+Left
Word Left Extend Ctrl+Shift+Left
Word Right Ctrl+Right
Word Right Extend Ctrl+Shift+Right
Word Underline Ctrl+Shift+W
on Dec 03, 2009 | Computers & Internet
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
Hello, I try to format my computer. Can someone help me please. thank you
most laptops that have the factory load on them, you restart and press a combination of either ALT F10, F11 or CTRL F10, F11 or just F10 of F11 by itself at boot up.
You should get a restore type menu.
Dec 25, 2010 | Computers & Internet
All of my Icons and start menu are gone. Emergency.
Oh No.. Delete is a button that can get you into trouble quickly. You need to find the RESTORE under system tools and try that. You could re-install the Operating System (OS) but this is a lot of work. The .exe file mean executable. That means that when you click on them something happens. You got a bad deal from Dell and yes they are overpriced. However they are probably right about a virus.Viruses corrupt exe files and cause problems. If I were to tackle this problem I would format to clear the viruses and install the OS
Apr 21, 2010 | Dell Inspiron 1545 Notebook
Left alt key not functioning in pagemaker
If you cannot access your Task Manager when Pressing the Ctrl+Alt+Del, this means you have a virus on your system which has disabled the task manager. If you have a good antivirus like Norton, Kaspersky or McAfee try scanning to detect the virus.
OR
Format your system, but before doing that makesure you backup your data before doing that.
Regards
Sep 16, 2009 | ASUS Eee PC 1000H Laptop
I have a gateway pc. I think I was hit with some
Restart the computer, try again. Nope? Try again.
(Press the CTRL , ALT, and Delete keys, AT THE SAME TIME. This will restart your computer)
Apr 12, 2009 | Gateway GT4024 PC Desktop
I can turn my computer on, but when it first comes on it says click enter to restart your computer. If you hit enter, it restarts, but it says says the same thing as before, click enter to restart your...
You may have a virus or root-kit infecting your machine. When you reboot, try booting into safe mode and run a virus scanner.
I am not sure what your technical know how level is at, but if you need directions to boot into safe mode, let me know!
Keith
Mar 30, 2009 | Everex StepNote NC1500 Notebook
Dell Latitude D620 Full System Recovery?
It's easy to miss the point at which you hit Ctrl + F11. You need to hit Ctrl + F11 at the point you see the blue bar across the top of the screen, it will display www.dell.com. If this is still not working you can use the XP operating system CD to reinstall XP and the Dell drivers CD to reinstall the sound, video, network and other drivers. If Dell didn't send you the operating system CD, you should contact them.
Jan 14, 2009 | Dell Latitude D620 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
