Question about Maytag Freezers
Bottom frezer working. top frige not getting cold, no cold air blowing in. Fan behind frige at bottom not moving
    Problem Solver:
  • 9 Answers
Dont know this model but it may have two compressors and only one working.
Posted on Apr 23, 2009
The top half is still working but the bottom half seems to have stopped freezing -- any ideas please?
There is a fan in the freezer compartment that blows cold air into the refrigerator part. If it is not working or if the baffle that directs the air is not functioning, that could account for the less than ideal temps.
Also check the auto defrost mechanism for proper operation.
Jun 23, 2015 | Freezers
Cold air is blowing out from behind the fridge on the ice maker side of my french door styl fridge. Is this normal
Good Afternoon Sharon Poirier, thank you for your post!
I understand that cold air is blowing from behind your Electrolux refrigerator on the side your icemaker is on. From what you are describing it sounds like a loose seal or missing plug. I would recommend having a professional technician out to your home to thoroughly look over your refrigerator. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Jan 11, 2015 | Electrolux Frigidaire Freezer Bottom...
My ice maker does not work
Hi there one of the biggest reasons for not getting cold which will affect the ice maker also is -- low or no air flow.
2 areas - 1) inside the freezer section are vents and they should have some clear areas (our freezer often gets crammed full of stuff)
2) under and behind the fridge is a dust bunny breeding area - pull the fridge out and get as much dust and stuff off the coils as possible (I use a vacuum and a small paint brush). The coils transfer the heat out of the fridge like an air conditioner. Be gentle - coils are somewhat fragile.
Some fridges have a faceplate that pops off at the front.
Sep 19, 2014 | Pragotrade 83-4020-W Weston 18In Frezer...
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
My freezer is not cold. The temperature dial reads 1-5 then an igloo and a snowflake. Do I put it on the snowflake to get it cold or the igloo?
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
May 01, 2011 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
My freezer does not work all of the time. I HAVE NOTICED that the freezer get very hot at the top of the unit, I have measured this with a digital therm.and temperture was reading 136 degree F. and,the...
The first thing to check is the condenser coil at the bottom of the freezer. Take the slatted front cover off at the bottom where the compressor is located. You will see the conderser coils. This looks like a radiator with aluminum fins, about 16 by 16 inches square. Be sure the coils are clean. Since the compressor is close to the floor it pulls a lot of dust into the coils. You may need to take a long stiff bristle brush to get as much dust as possible off the coils. If this is stopped up, the unit will definately overheat very quickly. While you are down there make sure the fan behind the coils is running. There are several reasons the fan might stop running. The motor can burn out, something can impede the fan blades such as paper, or sometimes rodents. If the fan isn't running the compressor will overheat and shut off. Once you check these basic things, you may then have to address the problem of dissapating the heat. The answer to your question is yes, it will shut down if it gets too hot. You need plenty of air space behind and over the unit in your situation. The air needs to flow into the front bottom section of this unit and flow freely out the back. All commercial refrigeration is designed to operate in 75 degree areas. As your room temperature increases the efficiency of the freezer will decrease. It is not uncommon to find these units in kitchens where the temperature is 85 even 90 degrees. They will continue to work, but will probably run all the time. I would think if you could get 3 to 4 inches of space at the back of the unit and the two feet above the unit with clean coils and properly running fans, you should get better results. You MUST have free flowing air to keep the unit running. The ideal situation is to have the air flow directly through from front to the back of the compressor compartment. In your case, you may have to move the freezer away from the back wall and allow the air to flow up the back of the freezer and out over the top into the room. 2 inch holes are not enough.
Sep 23, 2010 | True 23 cu. ft. / 651 liter Commercial...
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Open Questions:
Freezers Logo
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
