Question about Kenmore 24032\24036 Top Load Washer
Machine stopped won't drain and doesn't make sound when I try to turn it on. Do you think I need a new machine? Is it worth a service call? Machine is about 8 yrs old
  • Anonymous Apr 22, 2009
    machine stopped with a slight humming noise..sounds electrical. Checked the circuit breaking and resorted to wiggling the start/stop nob. No luck.
  • Timothy Shotwell
    Timothy Shotwell May 11, 2010
    Not to sound silly, but have you checked the circuit breaker?
  • 22 Answers
Sounds like you either need to find a timer for it or upgrade!! a timer might not be that hard to find and its definitally cheaper
Posted on Apr 21, 2009
Noises
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Washing machine won't stop draining
The pump triacc on the board needs to be replaced by a technician
It is cheaper than buting a new board
Apr 08, 2013 | Fisher and Paykel Washing Machines
Hp 7410: Error msg: Remove and check color cartridge. Is this a deathnell for this machine? I cannot seem to get past it even after removing and replacing.
There are several possible issues causing the problem. The color cartridge could be faulty. The contacts on the cartridge and the associated contacts inside the printer may be dirty. Finally, the cartridge chute may be damaged or printer may need service.
You can try a new HP cartridge. Next try cleaning the contacts with distilled (or bottled water) and Q-tips or lint free cloth. With the printer on, open the lid and remove the cartridges when they stop moving. Disconnect the power cord from the printer to stop the machine in the open state. Clean the cartridge contacts and the matching contacts in the machine. Dry the contacts with a new Q-tip or wait 10 minutes before replacing the cartridges. See http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=391194 for pictures. Then close the cover and reconnect power cord. You can repeat the cleaning step if it doesn't solve the problem.
If this doesn't work, look at the cartridge chute area to see if the spring is dislodged or the tab is broken. Again see the link above. In that case, the unit needs service. If it is under warranty, contact HP. Otherwise, decide if it is worth the repair cost.
I hope this helps.
Aug 17, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Dishwasher intake/drain light is on, removed and cleaned intake valve, no obstructions. Tripped the breaker to the power supply to no avail....any suggestions?
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Miele Touchtronic G894 SC Built-In...
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
54 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
