Question about HP Photosmart MZ67 Digital Camera
Mz67 HP Photosmart camera LCD screen has black line
There is a black line on the side of the LCD screen and it shows up on the pictures.
SOURCE:
SOURCE: Black LCD screen everytime i turn my camera on
On back of camera, under viewing screen, there is a little button marked "DISP" (display). When my viewing screens (on both my A75 & A85) went black, it turned out it was because the DISP button had been inadvertantly pressed. Pressing it again re-opened the viewing screens. Magic!
Posted on Oct 16, 2007
SOURCE: Can I use the HP Photosmart Mz67 Digital Camera as a webcam?
I've had mine for 1 day, and my answer so far is nope, at least I have not figured out a way yet.
Posted on Mar 20, 2008
SOURCE: lcd screen is black can't take new pictures
A620 friends: An idea - doesn't the screen usually go black when the batteries are very low? Could it be that this black screen problem has something to do with the battery connection -perhaps dirty, or a lose wire inside, or loose soldering? Just a thought.Linda k
Posted on Nov 09, 2008
zohail
  • 1223 Answers
SOURCE: LCD screen showing black screen
CCD FAILURE!
Call Sony for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 23, 2009
  • 102366 Answers
SOURCE: HP Photosmart M425, "Card Lock" message, camera
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Nov 05, 2010
Pictures are totally black
HI,
It seems you have a bad ccd imager and requires replacement.
go to your nearest service center and ask for replacement.
thanks.
Mar 29, 2009 | HP Photosmart M22 Digital Camera
LCD viewer screen blacked out
Really? Your lcd screen might be damaged! take it to someone who can tell if a pixel is damaged or not.
Nov 12, 2008 | HP Photosmart R725 Digital Camera
Slider switch view to take pcture
I had the same problem I just fixed today, is really easy to do it yourself the hardest thing is to disassembled you just have to take off the four screw at the bottom and there's another one in the battery compartment between Sd card slot and the 2 batteries to hold the silver plate on top is hard to see it, after you took off that little screw you can take off the top silver cover, after you took the silver cover off you'll see one more smaller screw on top of the camera under the silver plate you took off unscrew it and then separate both sides with a blade or some thing alse in mind (do it carefully it got a few small engagements around) after you did that you are ready to align the slider switch with its proper pin, youll see it. This helps to replace the lcd screen too, ones you are there. its easy hopefully it helps you
Aug 08, 2008 | HP Photosmart MZ67 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
No sound on my Mz67 camera
as far as i know those cameras do not have sound but they do have a mic. Try making a video,make some noise and put the video on your comp,from there it should be as clear as a bell.
May 26, 2008 | HP Photosmart MZ67 Digital Camera
Black smudge line on every digital picture.
It sounds as if you have some sort of foreign object somewhere in the optical path. Check the lens for any obvious signs of dirt, but failing that, it will need to go to a camera specialist for a proper clean. I would not recommend taking it apart and trying it yourself!
Matt
Feb 26, 2008 | HP Photosmart M537 Digital Camera
Can I use the HP Photosmart Mz67 Digital Camera as a webcam? Thanks! - Robin
Feb 01, 2008 | HP Photosmart MZ67 Digital Camera
HP Photosmart MZ67 Digital Camera Logo
105 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
