Question about Black & Decker String Trimmer Cordless 12" 18V
How to thread spool for black and decker strimmer
Three times I have tried to thread it and thread keeps snapping although I m only allowing 2 " of thread either side ..
Rethread grasshog
Posted on Apr 25, 2009
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Gls 220 auto strimmer
When putting new line on, it must be wound clockwise onto the spool
Jim
Jun 30, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
How to thread a strimmer Black and Decker
the spool itself had a direction how to wind the string.
Apr 28, 2008 | Black & Decker String Trimmer Cordless 12"...
How can i repace the line on a black & decker strimmer gl550
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,432 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
