Question about Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike
Stamina R360s UP/DOWN magnetic restistance buttons not working
I have used this product aprroximately 10 times. The up/down resistance buttons aren't working. I've checked the plug and replaced the batters with no luck. Unfortunately, it is set at a very high resistance right now, so it's uncomfortable for me to use. Is there any way to manually adjust the resistance?
  • andrehuff May 14, 2009
    I have the same problem but mine is set to the lowest resistance.
  • Anonymous Mar 31, 2014
    I can here the motor rinning when i push the buttons on the handle but the tension does not go up or down.
Mine did the same thing.. unhook the plugs that are under the seat running from the handles and touch a screwdriver to two of the prongs on either side of the plug and it will engage the button for you on which ever side you do it.. the up or down side
Posted on Jul 06, 2010
  • Sand Piper
    Sand Piper Apr 04, 2011
    The above statement is confusing. There are two plugs under the seat. unplug them and you will see four terminals on each plug. Two terminals are for the pulse monitor and two are for the up or down button depending on which side you're working on. My down button was inop. I used and ohm meter to determine that the switch/button had an open circuit and needed to be replaced. You need to be a bit mechanically inclined to replace the switch, assuming you can find one. I'm researching that now and will update when I find one. As stated above, if you touch a screwdriver on the two up or down terminals the motor should move and pull or release the cable going to the magnetic portion the bike. (be sure your batteries are good).
I had the same problem. after disassembling the entire bike and reassembling it, I noticed every time I pushed one of the up down buttons the LCD got dimmer. ===>
REPLACE THE 4 AA BATTERIES! Why this problem isn't in the owner's manual, IDK!
Posted on Feb 10, 2011
My resistance is not working. It is set very high and I can not use it. Any suggestions.
Posted on Feb 08, 2011
  • fixermac Feb 10, 2011
    replace the 4 AA batteries on the head unit, behind the LCD screen! I just had the same problem.
I need help if not do I need to buy a new bike my resistance is not responding it hard to paddle
Posted on Apr 28, 2015
I have a Stamina 4700R magnetic resistance recumbant bike. I'm looking for a place or website to buy plastic caps for the feet, a manual, and possibly the Stamina In touch fitness monitor. Where can I...
This is the main SITE for your unit, yet it appears to be an older unit, you can browse thru and maybe you'll find something similar to what you have and use that manual instead of the one you have. It probably won't be very much different from yours. As for parts, there are links on the page to find what you need.
Hope this is of help, Please rate and comment, Thank You
Joe
Sep 01, 2011 | Stamina Products Cycling
Ok i got this exercise bike at a yard sale its the stamina R360's and I didn't notice it doesn't contain the petal straps for it i need them for pt at home, tkr so my foot doesn't slide off...
Fixya does not sell replacement pedal straps and would not know of sources.
For a manual, try Googling (stamina)(R360s)(manual) without parens.
Aug 10, 2017 | Cycling
Stamina 15-1306 is not recording time, miles, calories, etc. Brand new.
The magnet located inside the right lower cover, which is attached to sensor wire needs adjusted. Just move it a little closer to Large sprocket which turns with the chain. Worked for me.
May 01, 2011 | Stamina Products Elite Recumbent Bike
I just tried my Stamina e-1000 eliptical for the first time. The electronic monitor comes on but doesn't do anything. It just reads zero. Any suggestion? Thank you.
Check the upper console to see if you have a loose connections and one of them is the speed sensor connection , if all connections are good then it looks like the sensor itself inside the main casing by the flywheel
May 16, 2010 | Stamina Products Stamina Pro 5300 Silent...
Whichever way u turned the adjustments, just do the opposite and maybe u will get a comfortable setting for ur workout......sodeep
Jun 17, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need the wheel bearing assembly for a Stamina bike model 890.
If your mechanically incline, Pull out old wheel bearing, if still in half way good condition, take to bike/auto shop see if they can find suitable replacement or rebuild the bearing it self. make sure when putting back in to use very good grease. I have same problem, since I can't find parts, those would be the best possible solutions.
Mar 16, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike Logo
4,047 people viewed this question
Top Stamina Products Cycling Experts
John Egan
John Egan
Are you a Stamina Products Cycling Expert? Answer questions, earn points and help others
