IMAGE DISAPPEARED... NOW IT TRYS BUT IMAGE WON'T APPEAR
DEAR SIRS: MY SCEPTRE 17" MONITOR MODEL #X7G-KOMODO-VII LOST THE IMAGE WHILE ON. I TURNED IT OFF AND WAS NOT SUCCESSFUL IT GETTING IT TO COME ON AGAIN...IT ATTEMPTS TO COME ON BUT FAILS. BOB MARTINEZ
  • 108 Answers
There is a possibility of loose connection check all its connector cords
Posted on Jul 22, 2009
Sceptre X7G komodo II Power light and screen flash about every second. Could it be the blanking circuit?
Look for bad caps with domed tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
should repalce the caps in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 24, 2011 | Sceptre X7G Komodo II 17 in. Flat Panel...
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
Monitor help
You need to enable the video-out port on the back of your laptop. The Fn+F8 key combination is common on Dell computers, but it could be different with your Vaio. Let me check ... yep, seems like Fn+F8 is the right key combination. What's your model #?
-Jon
Sep 01, 2009 | Komodo computers5: Sceptre X9G VII 19"...
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Sceptre 17" Naga monitor
try another monitor on your pc. I suspect bad video source.
Jun 09, 2007 | Sceptre X7G-Naga 17" LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
