Question about Nokia 6288 Cellular Phone
Nokia 6288 Bluetooth
I am having trouble with activating my blue tooth , it simply wont turn on, what could the problem be?
  • Anonymous Aug 22, 2008
    have the same problem bluetooth will not turn on have the same phone, hope u got yours working would like mine to work 2.
  • Anonymous Apr 14, 2009
    i can change all the other settings, but my bluetooth also will nt turn on, i press the yes button, and nothing happens..
  • 490 Answers
Problem is with the bluetooth so contact nokia care
Posted on Oct 14, 2007
SOURCE:
How to activate bluetooth on em350
go to ur start button, control panel, device manager or it will be in control panel somewhere(I don't have blue tooth) or just simply type in Bluetooth from your start button and see what comes up to click on to activate it
Apr 05, 2013 | Acer eMachines 350-2074 Netbook
My nokia c7 not connecting to HP pavilion thru bluetooth
Make sure that the blue-tooth is active on the PC and the phone. Now search for devices and when it detects , confirm the passcode and accept the device so as to allow the transfer of files.
Open blue-tooth settings in phone from settings and in PC from blue-tooth manager.
Apr 08, 2011 | HP Computers & Internet
Can u please tell where to find blue tooth on nokia c3110
To use the Bluetooth function on your handset, you will need to select Menu>Settings>Connectivity>Bluetooth. Then you will need to activate the feature. To do this, select ON to activate it. Then you will need to make your handset visible, to do this you will select visibility, or my phone's visibility, to the ON position. This will enable other Bluetooth users to connect with your handset for sharing. Note: You will have to accept when someone is trying to connect to your handset via Bluetooth if you wish to accept. To pair with a device, you will simply select search for device, and it will pick up any Bluetooth devices in the area. Please note that your device is Bluetooth A2DP capable, which means that you can use any Bluetooth technology equipnent that is A2DP and below, it is backward compatible. You will not be able to pair if the Bluetooth technology is greater than A2DP. You also have the ability to name your handset, to do this simply select My phone's name, and choose the name that you desire the handset to have. This will make it easier for someone to pair with you if you choose to share files.
Mar 20, 2011 | Nokia 3110 Cellular Phone
I have a nokia 6288 and need to transfer my sms off it to a pc i have no idea how to do this,I have no connections for my mobile,can I blue tooth or transfer onto another sim,thanks
there is a software commonly available on internet...named as SWITCH.. you can transfer not only your sms but contacts,calender entries, notes...to another mobile or pc..using bluetooth
Oct 13, 2009 | Nokia Cell Phones
Problem
reformat your phone.
May 15, 2009 | Nokia 6630 Handheld
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Nokia 6288
nokla n85 pls find solution.
May 03, 2008 | Nokia 6288 Cellular Phone
Nokia 6288
it could be software problem or it could be a problem with moisture(Liquid Damage) Get it checked from near by Nokia Repair Shop they will tell u one of these or they will tell that bluetooth ic(Bluetooth Module) is gon damaged
Apr 03, 2008 | Nokia 6288 Cellular Phone
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
Nokia 6288 Cellular Phone Logo
302 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
