Question about LG Flatron L1750S 17" LCD Monitor
Problem in TFT
A msg OSD Locked is always blink on screen of my TFT Whenever i press any switch(Menu or Autoselect)it shows the msg OSD Locked
THIS WAS VERY HELPFUL FOR ME, THANKS SO MUCH. I ALMOST THOUGHT I NEEDED ANOTHER MONITOR!!
Posted on Sep 24, 2007
  • 8 Answers
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Posted on Sep 25, 2008
2 Suggested Answers
DCSE
  • 191 Answers
SOURCE: Problem in TFT
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Posted on Jun 09, 2008
How to reset factory setting of monitor lg l1720B
Sounds to me like the button is stuck with pressure on the sensor. try moving button around a bit if it is a flat surface button then the surface is likely distorted and wont release it would have to be replaced at that point.
Sep 06, 2012 | LG L1720B 17" LCD Monitor
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
On screen show osd lock.pl.send solution.
Here is the solution for your problem,
1.If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
2.If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Thanks.
Have a great day.
Sep 04, 2010 | Computers & Internet
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Osd lock
Dear srinivasvodn,
Press the menu button of your monitor for a wile OSD lock will unlock.
Aug 05, 2008 | ViewSonic 17" CRT Monitor
Problem in TFT
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Sceptre naga x9 no osd
bad display board replace if you can find one on ebay
May 10, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
403 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
