Question about Dryers
Dryer does not blow hot air
Dryer blows only cold air
    Sniper:
  • 52 Answers
If this is an electric dryer, it could be the heating coil is broken or burnt through, you may have a restriction of built up lint in the vent hose, or one leg of the 220 volt breaker tripped. Please rate my solution.
Posted on Apr 21, 2009
4 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
dididsaythat
  • 291 Answers
SOURCE: Electric Dryer
Dont see a model # or make  but here some tips
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Posted on Oct 17, 2007
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
Why is my dryer blowing out cold air?
It sounds as though you have a defective heating element.
May 31, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
992 people viewed this question
Top Dryers Experts
