Question about Advent 4211c Notebook
My Advent 4211c will not charge.
It will work while plugged to charger. The battery sign is flashing orange
  • Anonymous May 22, 2009
    it only works when its pluged to the charger
  • p_amyl May 23, 2009
    same
Advent 4211c battery flashing orange
The MSI (manufacturer of this product) website has very poor product support - the only download is a BIOS upgrade for MSI-labeled units only. I could not find a user's manual to download, so I will give you a generic answer based on customary practice:
If the charge light is flashing orange, when previously it was green during charging, then the computer has detected a fault in the battery.
Nov 29, 2011 | Advent 4211c Notebook
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
Advent 4211-C won't power up on AC or battery. The only sign of life is the battery charging light which displays green continuously when the computer is plugged in to the mains... apart from...
You may have already tried this... Please remove the battery to see if the machine responds to pluged in power by itself. Press the power button for about 30 seconds befor pluging in the power... this is usually the way to reset the laptop. A defective battery can keep the machine from working.
If there is no response, the motherboard may have been damaged or a solder gotten loose, either way, it would need to be taken apart to verify and the solution could be expensive.
Aug 25, 2011 | Advent 4211c Notebook
My advent netbook is working when plugged in but the orange battery light is flashing and when i unplug it the whole thing goes off what do i do ?
unplug your battery when your pc is on AC power.and then plug in the battery quickly.do this until your problem eliminated.And one advice.do not use battery power upto it's last energy.Use it efficiently.and do not wait for critical alarm.it will reduce your battery life.
Feb 24, 2011 | Advent 4211c Notebook
I use an advent 4211c,it only works while on AC power and shuts off immediately i disconnect.it has never shown me this problem before and while i switch it on,it shows me battery is fully charge.I tried...
The problem is your battery pack. Just replace the battery pack the you have with a new one. But before using it, you need to recharge the new battery for 8 ~ 12hrs continues charging. After charging you can now use you laptop.
Jul 19, 2010 | Advent 4211c Notebook
I am having exactly the same problem
Its not recognising the power supply.Get the power supply checked in the laptop.
Jul 06, 2009 | Advent 4211c Notebook
Charging Problems
Try a different known working outlet just to make sure that its not putting out to much voltage and making the ac adapter to hot.
You also may want to try a different battery to make sure the battery isn't affecting the ac adapter.
If you do this and you are still having this problem then it could be a problem with the cells inside of the battery and you'll have to replace the ac adapter.
Jun 26, 2009 | Advent 4211c Notebook
Advent 4211 battery light flashes orange mains power only
Yeah the same has happened to lenovo x61s, i contacted the supplier and they told me i need a new battery, unfortunatly laptop atterys arnt the cheapest things around
Jun 07, 2009 | Advent 4211c Notebook
Advent 4211c Notebook Logo
713 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
