Question about Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder
Hi, I have a flat rear wheel. I must remove the wheel to repair it. I've removed the central locknut, but the wheel does not come out. There seems to be something else that must be done to remove the wheel. I will appreciate any help with this problem. Thanks
  • koerask1 Apr 22, 2009
    I will have to try and see if this works before I can say if the problem has been solved. Thanks
  • 32 Answers
Wd-40 and a rubber mallet tap around the wheel so not to bind one side, or you may have to take it to a dealer with a wheel puller, PS do not lose the key that holds the axle to the wheel
Posted on Apr 22, 2009
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
Adjust handbrake 94 libero
  • Remove the center console covering the parking brake lever. Locate the parking brake lever between the drivers seat and the front passenger seat. Put the parking brake lever in the lowest position.
  • 2
    Turn the cable adjuster locknut to make the nut loose. Find the nut at the base of the parking brake lever.
  • 3
    Raise your GT rear wheels using a jack and support the rear wheels using jack stands. Remove both rear wheels using a tire iron to loosen and take off the lug nuts. Take off the tire from the rods by hand.
  • 4
    Get underneath the car and remove the rubber hole plugs from the brake rotors. Locate the rotors on the underneath inside of the wheel wells.
  • 5
    Take off the brake calipers with a screwdriver, but do not disconnect the brake fluid lines.
  • 6
    Use a pry bar to push up on the parking brake self adjuster wheel. Locate this next to the brake caliper and it looks like a star wheel. Rotate this wheel until the rotors will not turn.
  • 7
    Turn the adjuster wheel five notches in the opposite direction. Reinstall the calipers and wheels. Lower your GT using the jack and remove the jack stands from the rear wheels.
  • Sep 13, 2012 | Mitsubishi Cars & Trucks
    I've changed rotors before but never on a 4 wheel drive. Could you tell me how to on a 1989 ford ranger?
    Brake Rotor (Disc) - REMOVAL & INSTALLATION
    1. Loosen the wheel lug nuts.
    2. Jack up the front of the vehicle and support on jackstands.
    3. Remove the wheel and tire.
    4. Remove the brake caliper assembly as described earlier in this section, but do not disconnect the brake hose.
    5. Suspend the caliper assembly by a piece of wire. Do not allow it to hang by the brake hose.
    6. Follow the procedure given under wheel bearing removal in Suspension and Steering for models with manual and automatic locking hubs (lines down).
    New rotor assemblies come protected with an anti-rust coating which should be removed with denatured alcohol or degreaser. New hubs must be packed with EP wheel bearing grease.
    1. Installation is the reverse of the removal procedure.
    Front Wheel Bearings - REMOVAL & INSTALLATION
    (see Figure 1 )
    Fig. 1: Inspect the bearings for abnormal wear and/or damage
    With Manual Locking Hubs
    (see Figures 2 through 17)
    1. Raise the vehicle and install jackstands.
    2. Remove the wheel and tire assembly.
    3. Remove the retainer washers from the lug nut studs and remove the manual locking hub assembly from the spindle.
    4. Remove the snapring and spacer from the end of the spindle shaft.
    5. Remove the outer wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
    6. Remove the locknut washer from the spindle.
    7. Remove the inner wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
    8. Remove the outer bearing cone and roller assembly from the hub. Remove the hub and rotor from the spindle.
    9. Using seal removal tool 1175-AC or equivalent remove and discard the grease seal. Remove the inner bearing cone and roller assembly from the hub.
    10. Clean the inner and outer bearing assemblies in solvent. Inspect the bearings and the cones for wear and damage. Replace defective parts, as required.
    11. If the cups are worn or damaged, remove them with front hub remover tool T81P-1104-C and tool T77F-1102-A or equivalent.
    12. Wipe the old grease from the spindle. Check the spindle for excessive wear or damage. Replace defective parts, as required.
    Fig. 2: Before beginning the wheel bearing removal, and after the outer hub is removed, wipe off any excess grease
    Fig. 3: After the grease is wiped off, remove the axle shaft snapring ...
    Fig. 4: ... then pull the splined spacer from the axle shaft end
    Fig. 5: Use a 4 pronged socket to loosen the outer wheel bearing locknut ...
    Fig. 6: ... then remove the outer locknut
    Fig. 7: Remove the lockwasher from behind the outer locknut ...
    Fig. 8: ... then loosen and remove the inner locknut-note the lockwasher engagement pin (arrow)
    Fig. 9: While pushing inwards on the rotor/hub assembly, remove the outer wheel bearing ...
    Fig. 10: ... then pull the rotor/hub assembly from the spindle, taking care not to scratch the bearing cups in the hub
    Fig. 11: Pry out the grease seal on the back of the rotor/hub assembly ...
    Fig. 12: ... then remove the inner wheel bearing. Thoroughly clean and inspect all of the parts for wear or damage
    continue...
    Jul 29, 2011 | 1989 Ford Ranger
    Remove rear brake drums
    Light Duty Models
    1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
    2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
    3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
    4. Install the brake drum in the reverse order of removal and adjust the brakes.
    Heavy Duty
    2. Remove the wheel. Loosen the rear brake shoe adjustment.
    3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
    4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
    5. Remove the hub and drum assembly from the axle.
    6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
    To install:
    1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
    2. Place the hub and drum assembly on the axle and start the adjusting nut.
    3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
    4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
    5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
    // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
    May 08, 2011 | 1991 Ford F250
    Rear wheel bearing
    if its like the 99 winstar:
    safely support the van, remove rear wheel, remove brake drum, remove grease cap. remove caged locknut assembly (38mm socket i think.) then pull the hub assembly from the axel. you may need to cut away the inner race if the bearing falls apart. clean axel, apply alittle anti size compound, then push on the new hub assembly. tighten down the hub nut to specifications (should be on the leaflet in the new bearing package), install dust cap, install drum, install wheel, lower and drive :)
    May 25, 2010 | 1998 Ford Windstar
    How do i remove the brake drum of a 1997 hyunidai excel do i need to remove the centre nut that also takes out the wheel bearing
    With Rear Hub Bearing
    1. Raise the vehicle and support safely.
    2. Remove the wheels.
    3. Remove the dust cap, cotter pin and loosen the locknut
    4. Remove the washer and outer wheel bearing.
    If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes.
    1. Remove the drum with the inner wheel bearing from the spindle.
    To install:
    1. Install the drum on the spindle.
    2. Install the outer wheel bearing and washer.
    3. Tighten the locknut to 108-145 ft. lbs. (150-200 Nm). Turn the brake drum while tightening the spindle nut to seat the wheel bearings.
    4. Install the cotter pin and dust cap.
    5. Install the wheels
    6. Adjust the rear brakes.
    Apr 23, 2010 | 1997 Hyundai Accent
    How do i fix a flat rear tire on a honda crf 150 f
    hi there you need to remove the rear wheel an then remove tyre fom one side of the rim to be able to pull the inner tube out pretty much the same as you would with a bicycle tyre and wheel and either repair the hole if repairable or simply replace the inner tube and refit tyre and wheel hope this helps you
    Dec 19, 2009 | 2005 Honda CRF 150 F
    Changing rear rotors
    ve wheel and then remove rotor if it has a locknut then remove that first and then the rotor should come free be sure and remove the brake caliper first the two bolts are located on top and botom of the caliper on the inside it requires a either a hex wrench or a starbit type of wrench...
    Dec 17, 2009 | 1998 Ford Explorer
    94 landcruiser brakes
    Rear DRUM instructions are first If you would Like Pictures and all They Must Be Emailed as TOO LARGE For FixYa's Format im at aol.com
    Just use my Knickname@ and let me know where to send.
    1. Raise and support rear of vehicle, then remove wheel and tire assembly.
    2. Remove brake drum. If brake drum cannot be removed easily, insert a suitable screwdriver through hole in backing plate, then push adjuster lever away from adjuster and back of adjustment tension.
    3. Remove tension spring, using a suitable tool, then remove rear shoe hold-down spring and pin. Remove rear brake shoe and anchor spring, Fig. 7.
      1. On Land Cruiser models, remove front hold-down spring using a suitable tool, then disconnect the parking brake cable from the parking brake bellcrank, Fig. 7.
      2. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, remove front shoe hold-down spring and pin, using a suitable tool, then disconnect No. 1 parking brake cable from No. 3 parking brake bellcrank.
      3. On 2WD T100 models, proceed as follows:
        1. Remove E-ring, then automatic adjusting lever and C-washer, then parking brake lever. Disconnect brake line from wheel cylinder using a suitable container to catch fluid.
        2. Remove wheel cylinder. Remove following parts from wheel cylinder: two boots, two pistons, two pistons cups and spring.
      1. On models except 2WD T100, remove front brake with strut, then disconnect parking brake cable from front shoe. Remove parking brake cable No. 2.
      2. Remove adjusting lever spring, then the adjuster from front shoe.
      Inspection
      1. Measure brake drum inside diameter. Inside diameter should be 11.61 inches,
        1. Measure brake shoe lining thickness, Fig. 3. Minimum thickness should be .04 inch on models except on T100 models and .039 inch on T100 models.
        2. Inspect brake lining and drum for proper contact and replace drum or shoes as necessary.
        3. Inspect wheel cylinder for corrosion or damage.
        4. Inspect backing plate for wear or damage.
        5. Inspect bellcrank components for bending, wear or damage.
        6. Apply a suitable lubricant to backing plate contact areas.
        Installation
        1. On 2WD T100 models, proceed as follows:
          1. Apply lithium soap base glycol grease to piston cups, pistons and boots.
          2. Assemble and install wheel cylinder.
          3. Connect brake line to cylinder.
        1. Apply high temperature grease to following parts:
        1. Apply a suitable lubricant to adjuster bolt threads and end.
        2. Assemble adjuster to lever, then install adjuster lever spring.
        3. On Land Cruiser models, install parking brake lever cable to parking brake shoe, then attach cable to bellcrank.
        4. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, install No. 1 parking brake cable to parking brake lever shoe, then attach the other side of cable to No. 3 bellcrank.
        5. Position front shoe in place with end of shoe inserted into piston, then install shoe hold-down spring and pin using a suitable tool.
        6. Assemble anchor spring to front and rear shoe, then install rear shoe with end inserted in piston.
        7. Install rear shoe hold-down spring and pin, then the tension spring.
        8. If necessary, adjust bellcrank as follows:
          1. Lightly pull bellcrank in direction "A", Fig. 8, until there is no slack in part "B".
              1. Rotate adjusting bolt until dimension "C" is .016-.031 inch.
              2. Lock adjusting bolt with locknut, when connect parking brake cable to bellcrank.
              3. Install tension spring.
            1. Ensure proper parking brake travel.
            2. Pull adjusting lever cable upward, then release and ensure adjusting bolt rotates. If bolt does not rotate, check for improper installation of rear brakes.
            3. Adjust strut to shortest possible length, then install drum.
            4. Pull parking brake lever fully upward. Repeat process several times.
              1. Remove drum, then check for proper clearance, Fig. 4. Clearance should be .024 inch. If clearance is not as specified, check parking brake system.
              2. Install brake drum, then bleed and refill brake system.
              3. Install wheel and tire assembly, then lower vehicle.
    FRONT ROTORS & PADS
    1. Remove caliper.
    2. Remove cap and snap ring, Fig. 10, then remove cone washers with tapered punch.
    3. Insert suitable length bolts into flange bolt holes, then tighten bolts evenly and remove flanges.
    4. Remove free wheel hub cover and snap ring, then remove nut, spring washer and cone washer with suitable tapered punch.
    5. Remove free wheel hub body and gasket.
    6. Remove locknut, lock washer and adjusting nut.
    7. Remove axle hub and brake disc as an assembly.
    8. Remove oil seal and inner bearing from hub.
    9. Reverse procedure to install. Torque adjusting nut to 43 ft. lbs., then back off nut. Torque nut to 18 ft. lbs. Using spring scale attached to hub bolt, check that preload is 1.4-12.6. Install lockwasher and locknut, if equipped. Torque locknut to 35 ft. lbs., and recheck preload. Secure lockwasher by bending one tab inward and one tab outward.
    1. Raise and support front of vehicle, then remove tire and wheel assembly.
    2. Remove clip and hole pins, Fig. 9.
    3. Remove anti-rattle spring and shim(s) if equipped, then remove brake pads.
    4. Lubricate caliper housing with suitable brake grease at pad contact points.
    5. Reverse procedure to install.
    Jan 28, 2009 | 1994 Toyota Land Cruiser
    Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder Logo
    106 people viewed this question
    Top Quickie Wheelchairs Health & Beauty Experts
    wcdoc1953
    wcdoc1953
    Colin Taylor
    Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
