Question about Nokia 6230
Charging problems The battery is never getting fully charged when I put the phone on charge. You see the moving bar display indicating that it is charging but the battery never gets full. The phone is only a year old Any ideas??
    Problem Solver:
  • 12 Answers
Yes it might be the pbm of Either the battery or the phone. if it lies with the former pls replace else we have to check the phone. contact nearest service center.
Posted on Sep 22, 2007
How do I know when my lg 2 extravert 2 is done charging
The battery bars indicator at the top of the screen will be full and when fully charged the message will say battery fully charged, if you unplug the charger and reconnect and the battery is fully charged you will see this message!
Oct 18, 2014 | Verizon Communications LG enV Cell Phone -...
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
My battery on the tool bar has got an x on it and says it is fully charged but when put into another laptop it says charging
I understood your problem ,
actually on windows task bar you will see the battery symbol...and as you mentioned in your question that red X on that.
It cause due to the over charging / very less charging of battery...You should charge your laptop for just 2hrs only which is enough time to full charge your laptop..
here as your problem which indicates you need to replace your battery with new one....then test it...and be careful with new battery.
Thanks for giving me opportunity to solve your problem..
please give your Rating!!
Jun 17, 2011 | Acer Aspire One Netbook
Battery light dosent work during charging or fully charged. Light comes up at times. battery level is either not indicated properly
In most models the battery light is displayed when it is charging with a possible blinking when it nears charging and it cuts off when the charge is full.
So if your laptop shows that the battery is charging in the task bar- bottom right, then you can ignore the issue unless your laptop is in warranty and it can be done free of cost.
If you open power options in the control panel the charging will be displayed , if this show Ok then the fault is the hardware circuit issue on the mother board power section.
Jan 22, 2011 | Computers & Internet
Playstation 3...Battery in controller is low, plug in controller
The dead give away for a dying controller is the red light on the numbers will flash.
When you plug your controller in and hit your PS button, at the top you'll see a controller symbol and a battery icon. If the battery bars are moving then it's charging. When it's fully charged it will display 3 bars solid even when plugged in.
I've been wrong before; but I'm 99% sure you cannot turn off the system and have the controller charge. As far as I know the system must be on while charging the controller. From my experience it takes about an hour or 2 to get it fully charged.
Good luck and if i've helped you please give me 4 thumbs up!
Feb 07, 2010 | Sony PlayStation® 3 (80GB) Console
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
I just opened a new motorola razr v3 mobile phone and have put in the battery and am trying to charge it but there is absolutely no signal at all to say it is charging. It has been charging for about an...
hi,there.. what's happen with your new phone is normal and nothing to worry about it... usually at the manual book from phone factory the recommend to charge battery for first time use is about 4 hours. after this next time if you want to charge battery i suggest only if only left 1 bar battery indicator at your cell main display....
Feb 03, 2009 | Cell Phones
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nokia 6230 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
