Question about Mitsubishi WD62527 62 in. LCD HDTV
Green Blinking Timer Light Mitsubishi WD-62527
When I plug in my Mits WD-62527 the Green Timer light blinks rapidly for about 1 min. and then blinking light turns off, After the blincking light turns off I then try and turn on the set from both the remote & front panel buttons, but the set does not come on, Green blinking light stays out for about 1 min. and then starts blinking again (repeat process). I've tried the System reset button as the manual specifys and also unplugged the set and left unplugged for 1 hour but still get the same results when I plug back in. This TV has litterally got probably 20 hours use on it.. Any suggestions?
  • 5 more comments
  • hercules6 May 03, 2008
    same exact problem
  • Anonymous Jul 08, 2008
    i have the same problem as the blinking green light.  in trying to correct this problem, i held down the recommended suggestion of holding down the menu button for 10 seconds and then press the power button.  the tv was still not coming on showing any picture.  please recommend another option.
  • doeandrea Aug 27, 2008
    In the last month i have had the "driver" replaced, the "color engine" replaced (for the 2nd time), and some sort of cable replaced on my WD-62527...all three with separate service visits...and now I have the problem of when I try to turn the tv on there is a clicking (like it is going to power up) then the light turns solid red. After unplugging (or resetting) the tv, the green light blinks for about a minute and then goes dark. The process repeats and repeats until eventually the tv will turn on. I have been told there is a way to get the error codes by pushing two of the buttons...does anyone have a clue what two buttons I should hold down? I have a call into the service guy...I will post how this resolves.
  • art2668 Dec 02, 2008
    My tv turned off by itself and the green timer lights starts to blink, the blinking goes off after about 45 seconds, when I try to turn the unit on the timer light starts to blink again. I did unplug and push the reset button, I even put the surge protector. The problem is still the same, I cannot turn the tv on.
  • Anonymous Dec 22, 2008
    I need it for manday night football in 2 hrs... please help
  • Anonymous Mar 14, 2014
    roku box light does not stay on I unplug for about 10 min. still does the same thing
  • Anonymous Mar 19, 2014
    I get a steady red light on the bottom left of the tv where it says status. I tried to unplug it and plug it back in. The power light flase blue for about 10 seconds then the red light comes on again.
I have the same problem. I was told it's the dm board/dlp chip, and the tv may have taken a power surge. cost about 400.00 for the part.
Posted on Feb 14, 2010
Hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
SOURCE:
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
Mar 31, 2012 | Mitsubishi Televison & Video
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Mar 07, 2009 | Mitsubishi WD-62827 62" Television
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
''Mits'' WD-65733 blinking timer light
The green LED is blinking because there is fault in the TV you will have to take to a technician to determine the cause.
SUPER8
Nov 24, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD62527 62 in. LCD HDTV Logo
2,496 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
