Question about Garmin GPSMAP 498C Sounder GPS Receiver
GARMI GPS 498
Broke power connector pin on unit…can I buy part and fix myself or do I need to get repaired by pro?…thanks
  • 83 Answers
I would contact Garmin and get their price for a repair. Navigation is too important to trust to a repair that may or may not be correct. Just go to http://www.garmin.com and click on the support tab.
Thanks for using Fixya.com
Posted on Apr 22, 2009
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
My Garmin GPS 498 stopped locating sattelites. How can I fix it?
Power off the Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode. I hope this helps. Good luck
Mar 14, 2011 | Garmin GPSMAP 498
Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Nov 07, 2008 | Garmin GPSMAP 498
Power connector
i have these power ports and can also help repairing it for anyone thats not able to do it themselves. wmetz@comcast.net
Sep 08, 2008 | Magellan Maestro 4040 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Opening the case to repair broken power connector
FIRST FAIR WARNING: This take apart is best left to the repair tech's at an authorized repair facility. There are 6 snaps, two on the top, two on the bottom and one on eash side. I used a thin blunt tip letter opener and started at the top. This didn't leave any marks on the case that would tip off the repair tech's that you goobered it up inside which you will do if you proceed! Release the two at the top first, then the two on the bottom. Now release the one on the side where the power button is located. Open the case on the power button side only about 1/4 inch and slide the bottom off the top being careful not to separate the power cord and headphone connector plugs from the board that they a fastened to inside the case. SECOND FAIR WARNING: It is very easy to pull the connector plugs from the board and this will really convince the repair tech's that you ruined your $350 GPS. Good luck and don't say I didn't warn you!!!!!!
May 13, 2008 | Magellan Maestro 4040 GPS Receiver
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
No power
Two possible solutions. One is that you buy a cradle in which you put the gps unit on it or just buy a new one. Usually if the pin is broken, it needs repair.
Oct 18, 2007 | Magellan RoadMate 300 GPS Receiver
Where can I buy spare parts?
http://www.gpsw.co.uk/cats/cl3_224.html try that one or ebay parts
Nov 14, 2006 | Garmin GPSMAP 182C GPS Receiver
Garmin GPSMAP 498C Sounder GPS Receiver Logo
223 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
