I want to put another hdd in my older computer
I have an older p3 gateway E-3200 and i want to add a second hdd to it. it has a spot to put a second hdd, and an open power plug, but the ide cable has only one plug on it. i have an ide cable with plugs on it for two hdds, and i want to know if i can just switch them without any problems. is it as simple as just plugging the one i want in? thanks
  • 2,229 Answers
Yes, you can use your other IDE plug.
Look at the jumper settings on the hard drives--one must be set to master and one to slave.
Or--you can set both to cable select, but that means your original hard drive has to be at the end of the cable (assuming you want it to still be the main drive).
There you go!
Posted on Apr 21, 2009
  • 155 Answers
The only thing you may take into account is the jumper setting. The second HDD must have the jumper in the SLAVE (SL) or CABLE SELECT (CS) position.
Gateway all in one touch screen went all black one long and two short beeps.what happened
Ok first turn the power off at the wall & disconnect the power cable, now open your computer. Once open if you do not have an ani-static strap simply touch the case to discharge any static and keep your hand there. Whilst you have one hand on the case with the other hand gently press down on the ram & any add-on cards to ensure they are seated fully, secondly again whilst still holding the case with 1 hand make sure that all other connectors such as power, hdd, etc & all connections to the motherboard are fully seated. Then after you have done all this plug you power cable back in and re-connect the power cable to mains & try restarting your computer if it starts as normal then it was one of the components had creeped up with the cycling up & down of the pc this is a normal thing due to expansion & contraction of the metals etc that make the components up inside your pc. If this hasn't helped then turn it off at the wall again & disconnect power cable from the wall & computer then you can take out all add-on cards & add the power back to the system & start up your pc if it doesn't start then it is the hdd has either failed or become corrupted & will either need to be recovered professionally or repaired or replaced it is cheaper to replace a hdd than to have it repaired. Yet if you computer starts then shut down add 1 add-on card back to the system & start up if it starts with that add-on card continue to add the add-on cards back in until it fails that's if it a case of an add-on card failing. If it is an add-on card that has failed simply purchase a new add-on card & install remember to remove the old add-on card prior to adding a new 1 unless it is the exact same add-on card to avoid conflicts.
Oct 14, 2014 | Gateway Computers & Internet
Windows pc laptop
Simple answer is no.
Nov 25, 2013 | Gateway Nv55s17u Laptop
Add 2nd HDD to Gateway DX4860
https://www.youtube.com/watch?v=ujue-ZWBIp4
May 10, 2017 | Computers & Internet
ADD OPTICAL DRIVE TO GATEWAY FX6840
OK add one. All you do is take the old one out and put the new one in after you open the case and unplug the power cord. There might even be an open slot under or above the one that is already in the computer so just push the plastic covering that faces the front of the computer out so the new optical drive can go in it's place. By optical drive you are talking about a DvD or CD player, right?
Apr 02, 2012 | Gateway FX6840-03e PT.GAT02.023...
I need a new graphics card with an HDMI output, preferably 1gb, for the Gateway SX2803-25e computer recently purchased.The one furnished with the computer will not support many online games. Can you...
You have a PCI Expres x 16 expansion slot so can can pretty much put any video card into it. But don't know how much space you have in the case , you might need low profile one. Or just how much money you want to spend. Here is an example of a 1GB low profile card that have HDMI out. EVGA 01G-P3-1302-LR GeForce 8400 GS Video Card - 1024MB DDR2, PCI Express, DVI, VGA, HDMI, Low Profile
You can do a search on this card.
Mar 15, 2011 | Gateway Desktop / Intel Pentium Processor...
I WANT TO KNOW HOW TO ADD A SECOND HARDDRIVE TO MY GATEWAY ESSENTIAL 500 COMPUTER
If your additional Hard drive is SATA use SATA cable and SATA power to get it done.
Or else use IDE and D type power to connect.
Make sure that you have switched off the computer before installing the HDD
Thanks,
Satheesh
Jan 21, 2011 | Gateway Essential 500 PC Desktop
I want to reset my Gateway LX6200-01 to factory settings
Hello!
If you computer can go to the system, few second or more, maybe you have trouble with heathing, and clear cmos isn´t solution for that.
Than you need good expert for repair you computer.
Oct 30, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
I do not have a router because i live in the country and the only way i could go was a sprint aircard and i wanted to see how i could use that to connect the internet to a ps3
You will need a second Wireless LAN Card or USB Wireless device for the P3, then install all SW for the devices, set BOTH computers to have the same workgroup name (Rt click My Computer, Properties, Computer Name, Change) then reboot both boxes.
Log onto the Aircard box
Goto to Start, Settings, Networks and Settings
Double click Aircard
Click Properties
Click Advanced tab at the top
Click Allow other to share
Click settings
Pick your poison
Add any extra you need
Click OK 2x
Goto start, Run and type cmd
type ipconfig /all
write down settings
Goto P3
goto Start, Settings, Networks and...
Double click the WLan icon
click properties
On the top scrollbar find TCP/IP and highlight it
click properties
change IP to Use this IP and set to same as Aircard +1
Massk is same
Gateway is same
DNS is same. If no DNS make this PC same as Aircard IP
type ipconfig /all
write down settings
Type PING www.xxx.yyy.xxx (IP of Aircard to see if P3 can SEE it
if OK, then open Browser and come to this site ;-)
If not OK (Ping timeout)....
go back to Aircard PC
Click Start, Settings, Networks and Settings
Right click Aircard
Click Properties
Click Advanced Settings
write down all these
WLAN protocol: 802.11a,b,c,g....
Channel
SSID
Encryption type (changge if P3 does not support)
Password (copy to .txt file and save to memstick or floppy)
Go back to P3 and do same
Then click scan for hosts
find your Aircard name
Click connect
copy/paste ot type in Password from Stick or floppy
try open browser again
Easy!
Jan 17, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
