Question about Pioneer DV-373 DVD Player
Progressive scan accidentally i was turned video output to progressive scan-pal,now the TV screen is appearing only black,and how to get back normal mode,and i have also lost my user manual.pleaseeeeeeeeeeee send me solution this problem. thanking u sir
  • 1 more comment
  • sigit_tax Feb 12, 2009
    the display in screen show progressive
    i can't back the first setting please help me back the setting
  • carlangas34 Mar 22, 2009
    my dvd player is in progresive mode i wanna play my movies in normal mode, i cant see eny movieeee!!
  • ifixlah May 11, 2010
    any movie i do play, all display in black and white. What could be the causes? Can anyone suggest.
Lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Posted on Nov 15, 2007
Accidentally i was turned video output to progressive scan-pal,now the TV screen is appearing only black,and how to get back normal mode,and i have also lost my user manual.pleaseeeeeeeeeeee send me solution this problem.
Posted on Jul 17, 2010
Perfect, I worked for me! thank you
Posted on May 19, 2009
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
No VCR/DVD Picture or sound
Your unit may have been switched to Progressive Scan mode, which a normal analogue TV can't recognise. Check your VCR/DVD manual for instructions to change picture settings and set it back to PAL TV.
Failing that try a new 3 conductor lead from unit to TV.  Also unless you yourself were actually the one who accidentally unplugged the unit, it is just possible that whoever did has not (for whatever reason)disclosed to you the full detail of what actually happened to cause it to fail. If it was in fact dropped or fell, pulling on the AV leads they could have been rendered useless or the unit itself might have suffered a Gforce-shock causing component failure or circuit board fracture.
All the best with this one
Anthony
Oct 17, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
Pioneer DV-373 DVD Player Logo
492 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
