Question about Chevrolet Vehicle Parts & Accessories
I lost all three sets of keys to my 1990 chevy liumna and one of my friend told me to just brake the pins so i did but the security system wont let me start the car how do i turn it off?
If you had the chip in the key it will take a bit but you have to figure out what resistance the chip was and add that into the 2 wires at the top of the ignition switch.
Posted on Apr 24, 2009
I have a 2002 chevy pickup, lost the key, put a new steering column,will crank up and run for 10 seconds then die. I spray gas in the throttle body and it stays running as long as I'm spraying gas.
If you lost the key and you have passlock security system, the key is just a mechanical key. It's the key cylinder/tumbler that communicates with the passlock system. No need to replace steering column. Just my opinion.
You could get a locksmith to make you a key that will work or get a key from local dealership. If the key is the problem? The key has no pellet and no transponder.
Is there a security system lamp on the dash that is on or flashing? Any applicable trouble codes?
There is a relearn procedure, 10 minute segments, about three segments for a total of thirty minutes. Did you do the thirty minute procedure? Ok the make is a chevy, I don't know the model, may not matter?
Sep 23, 2017 | Cars & Trucks
2003 chevy s10 security systems not starting
If when you attempt to start the vehicle, the "theft" or "security" light is flashing; apply parking brake (this turn off the auto headlights), turn ignition on. Security or theft will flash. Leave vehicle in this position for approximately ten minutes. Security or, theft will stop flashing and then you may start the vehicle. This is a VATS security soft reset. If it does not reset after ten minutes you may need to do a hard reset, which is three sets of ten minutes.
Feb 17, 2014 | Chevrolet Vehicle Parts & Accessories
My 1999 chevy blazer doesn't even try to start the security (factoryinstalled) blinks constantly. I was told it may be the pass lock system any ideas?
The pass key system isn't working. Make sure your using the same key.There is a piece where a wire brakes in the steering column. Part is cheap but steering wheel needs to be pulled. And dealer needs to reprogram it.
Jul 02, 2012 | 2002 Chevrolet Blazer
How do I reset the security theft on a 1990 pontiac bonneville
This link will help you out. Has alot of information on the system.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Dec 22, 2011 | Cadillac DeVille Cars & Trucks
Lost 1995 keys to 1995 cadillac eldorado. How can i obtain w/o spending 100's
This car key has the VATS security chip in it. These keys are at least 100 bucks. You can rip into the ignition part and start the car with the wires, but it wont work untill you bypass the SECURITY system. Here is a link about the security. Gives you the 15 possible key chip codes and links to help bypass this system.
Jun 06, 2011 | 1995 Cadillac Eldorado
06 ford focus..when pushing start button it just clicks and lights flash.did not use hood pin and was told to not use brake connection,still nothing
try putting the key in the ignition switch, leave it in the off position. Now remote the car, if it starts and stays running, you need to reposition the transponder loop
Dec 27, 2010 | Remote Starter with Keyless Entry
Does truck have to be running on my 1990 toyota 4-runner 4x4 ?
No, you can do it without the engine running. The power assist just makes braking easier. Just make sure you don't move the pedal till the bleeder is tight, then pump it back up an do it again. Start at the right rear and move towards the front left. Hope this helps.
Jun 16, 2010 | 1990 Toyota 4Runner
2003 Chevy silverado wont start. it has gas, we
Its possible the security system has been set off. The security light on the dash will stay on if this is the case. The cause can be the key tumbler if it is the security.
Jan 20, 2010 | 2003 Chevrolet Silverado 1500
Having trouble with the brakes on my 1990 buick reatta
assuming that brake fluid is ok you need to first check most common problems like worn out pads, bleed all lines to brake cilinders, and check vacuum to power brake booster if any. if all of that is done and still have same problem then abs system may have electrical problem.
Apr 07, 2009 | 1990 Buick Reatta
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
