Question about JVC GR-X5U DV Digital Camcorder
Formatting SD Card to shoot stills
Following the steps in the manual to "initialize" the SD Card, I cant get the screen to show the Format menu. Its keep going to the Video Playback Menu ( even when Video/Memory switch is set to Memory). I cant shoot stills until I format the SD cards, right? I have a Panasonic 4GB HC SD card. Help please. Thanks. Wilfred
    Genius:
  • 1,234 Answers
Hello Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Unable format micro sd
    Try to format it using this low level format tool -> http://scut.co/n4b
    Remember to select correct drive.
    Aug 17, 2013 | Electronics - Others
    Installation CD & Quick Guide
    Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
    Oct 03, 2007 | Megxon X33 Digital Camera
    I cant take pictures because shows the card is full, how can i erase the sd card
    You can erase in the camera, or format the SD card. Or open Start Menu, Computer, Click on the SD card, open, select ALL, delete, OR, right click on the SD card, format.
    Jan 16, 2013 | Sylvania G-Netbook
    How to calibrate Vtech Storio?
    https://vtech.box.com/s/68ee102d30c31a7c5a4d
    If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
    •Please firstly download the SD Card Recovery Creator
    •Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
    •Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
    •Click 'Make Recover Program Card' then click 'Next'
    •From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
    •The application will now format the SD card with the Storio factory default operating system
    •When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
    •Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
    •Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
    Feb 15, 2012 | Vtech V.Reader Interactive Reading System
    Formating SD card
    You can do the steps indicated in this manual:
    Hope this helps you. Please let me know.
    Sep 22, 2009 | HP Photosmart 735 Digital Camera
    How do I initialize the card?  The camera won't let me shoot, a message pops up says card is not initialized.
    The manual gives three options if this warning shows.
    (1)
    The memory card has not been formatted.
    To format the card select Format on Setup Menu 1.
    (2)
    The memory contacts require cleaning.
    Clean the contacts with a soft dry cloth.
    (3)
    Camera malfunction.
    Contact a FujiFilm dealer.
    Jul 11, 2009 | Fuji FinePix S2000hd Digital Camera
    When i put my r4 into my ds its just says cant find menu?
    hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
    To format the 2gb micro sd card
    1. Insert sd card into usb stick and into usb port.
    2. Close autoplay screen if it appears.
    3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
    4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
    To reload firmware
    1. Insert cd into pc cd/dvd drive.
    2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
    3. Once copied, check removeable drive to ensure files and folders have copied over.
    4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
    this normaly sorts this out. paul
    Jul 07, 2009 | Nintendo DS Lite Console
    Cant format sd card
    Your sd card may have too much memory or it may be an hd
    Mar 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
    Card Not initialized
    you just need to format the memory card again, go to the set up menu and format. you will loose any pictures that you may have on but it will work again. you can download a manual for your camera, the fuji finepix s5100 at the following link and following the steps to format the memory card on page 76. here is the link: http://www.rug.nl/rechten/voorzieningen/audiovisueledienst/productendiensten/handleidingen/finepix_s5500_manual.pdf
    Jun 27, 2008 | Fuji FinePix S5100 Digital Camera
    Card not initializing
    give it a try,. good luck
    JVC GR-X5U DV Digital Camcorder Logo
    104 people viewed this question
    Top JVC Video Cameras Experts
    Steven Wander
    Steven Wander
    Mohamad Abdan
    Mohamad Abdan
    Marvin
    Marvin
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
