Question about RCA 27F530T 27" TV
VID1 showing unusable signal
I've been viewing DVDs on VID1 but now it says "Unusable Signal" It shows up on CVID2, but it's weird colors - green & red (it has always done this.) I've checked the cables and they seem okay to me, (tho I'm not the one who hooked them up). I can't think of anything that would have been changed. Why would this be happening? How can I correct the color on CVID2?
    Problem Solver:
  • 12 Answers
If you have been using Vid1 with your DVD and have NOT changed it, make sure that the connection has not come loose, just a slight jarring can cause the problem.
2) You might also want to clean the contacts with "contact cleaner" available from a Electronics store.
3) Try a DVD that is a known "good" DVD in your DVD player, if that works, well you know...
Posted on Oct 11, 2007
  • Robert Young Oct 22, 2007
    Might also try "known good" cables, the message means you are NOT getting a connection.
SOURCE:
Unusable signal
This is a resolution mismatch problem. One of the devices will not accept the resolution of the other. Try another type of connection or try another input.
Apr 13, 2014 | Sony DVP-SR200P DVD Player
Unusable signal is being displayed on television although it is connect to a digital cable box. It gives the same error even when connected to an analog cable box
You will need to have the tuner checked out, try connecting your cable box using the audio/video inputs to your tv(vid1, vid2 etc.)it should give you a normal picture.
Jan 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio [email protected]
Jul 23, 2009 | RCA HD52W58 52" TV
I am having a problem with an RCA tv..unusable signal.
make sure that you have it set to the right input signal source and that your source is working properly. if so then yeah, you need to replace the fuzle modulator.
Mar 11, 2009 | RCA L46WD22 Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Sep 07, 2008 | Televison & Video
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
