Question about Zanussi 18 in. ZDT5044 Built-in Dishwasher
3 beeps when i start a program
I have a zanussi dishwasher that beeps 3 times when I start any program. The book tells me that it has something to do with flooding. Can you help
4 Suggested Answers
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
SOURCE: dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Posted on Jan 23, 2010
ercupa190
  • 12223 Answers
SOURCE: zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Posted on Apr 02, 2013
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
Zanussi dishwasher anti flood device
There is a water level pressure switch that is your issue. Replace that or if youre lucky, clean the hose/pipe connected to the pressure switch and it could work again.
Feb 10, 2016 | Zanussi Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
After selecting a program, the dishwasher beeps for a while and the 3 buttons on the left flash too. Program wont start, water wont fill and nothing happens. THe lights keep flashing but the beeps stop for...
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Aug 13, 2010 | Hotpoint 18 in. DC28 Slim-Line Built-in...
I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
May 15, 2010 | Electrolux Dishwashers
I need to find the anti-flooding trigger. I have read the Manual already and identified the problem. Flashing lights and Continuous beep when attempting to start program. Program does not start.
Usually there is a float device at the base which is getting obstructed. Something stuck under it.
Remover the obstruction and check the float can move up and down when pressed.
This might fix the problem you are having. Would have helped if you had provided the actual model of your dishwasher.
May 09, 2010 | Dishwashers
Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Nov 06, 2009 | Dryers
Zanussi 18 in. ZDT5044 Built-in Dishwasher Logo
113 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
