Question about Jensen JER-323 Remote Control
Kids locked up the TV, need code to unlock it.
We have a Jensen tv, the code on the remote is RC-A26-0C. The kids have somehow locked the television up. All that comes up is a blue screen with a red padlock in the upper left hand corner. Nothing we have tried will unlock it. Help, please!
    Sniper:
  • 75 Answers
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Posted on Apr 21, 2009
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
How to unlock jensen TS2750J parental control lock?
Hello
To unloxk your Jensen TV do the following.
OK.
Feb 22, 2011 | Jensen TS2750J TV
Tv's locked, in need of assisstance
unplugg tv and take batteries out remote for 15 minutes and let them reset themselves
Nov 18, 2009 | Jensen TS2750J TV
Hi, I have a problem with my rca television model number RCAS01BA. My dauther has somehow put the child lock on without using the remote control as we had lost that a couple of months ago. (God bless...
You don't need the remote to unlock the TV. Any RCA universal remote will change channels etc if you want a remote.
Now from the manual: simultaneously hold down the menu/OK button and the Volume down button for 3 seconds. This resets the pasword and unlocks the TV. You can then enter the menus as usualI believe to control/clear parental settings etc.
May 22, 2009 | Televison & Video
Unlock jensen rc-a26-oc
Thanks fixed my problem
Aug 31, 2008 | Jensen Q2749J 27" TV
Remote control code
have you got the code for a urc22b remote code for a matsui tv
Jun 11, 2008 | Jensen JR500 Remote Control
Tv is lock
i picked up the remote control an it lock the tv so i unplug it to try to rest it an u can turn it on at all
Feb 25, 2007 | Jensen Q2749J 27" TV
Televison & Video Logo
453 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
