Change margins HP 3525dn color laserjet...change margins
  • gracia395 Apr 21, 2009
    any idiot knows how to set margins in a program...I'm talking about printing from Firefox browser. It's a database that asks one to set the printer to .5 margins.I used to be able to do it with a HP laser 4m & FF 2
    Problem Solver:
  • 8 Answers
You should set the margin from the application your printing from. C.-a.-d. if you print from a Microsoft Word document, you should set the margins in this application
Posted on Apr 21, 2009
HP Laser Jet 3525dn printer shows lines every 1/4 inch on each page after printing?
If the lines are always the same color then likely you have a bad cartridge, that or it might be a failing fuser.
Mar 15, 2015 | HP Office Equipment & Supplies
Hp Laserjet 1020 Left Side Margin Problem
change your drum or teflone inside the printer
Jan 22, 2014 | HP LaserJet 1020 Printer
How do i adjust the margins from the printer? HP color laserjet 4600 dn printer
Usually in "page preferences" in the file drop-down bar. Then use "print preview" to see if the page looks OK.
Mar 22, 2011 | HP LaserJet 4600dn Color Printer
Change margins on an HP4050N
Right click on the printer in control panel and click properties, look around for margins.
Jun 10, 2009 | HP LaserJet 4050n Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
HP 3900 laser printer
change the yellow toner
change the black toner
before change toners tray to clean printer inside carefully
Sep 11, 2007 | HP LaserJet 3600n Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
609 people viewed this question
jasbo
jasbo
