Can't connect Sirius radio using our office wireless connection
We are not able to connect a Sirius radio wirelessly in our office. We have a NewWave Base II. I have a network name and a network key but that does not work. The network name shows up on the Sirius radio but the password (which we are assuming is the network key) does not work. We have a Verizon DSL line but they will not help us.
Thank you,
Diana Campbell
postscript
  • 48 Answers
SOURCE: Forgot the Network Key
you can get the network key if you can connect a computer directly to your westell modem. you can use any of the 4 ports on the back of it labeled E1,E2, and so on. then open your internet explorer and in the address bar type any of this http://dslrouter or http://192.168.1.1. next click the configuration menu on the top then select wireless. you'll see there the security or authentication type.
if you really want to reset the modem, press the reset button on the back of it for 5-10 sec.
Posted on May 27, 2008
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
SOURCE: Connection using DSL-2640T
Try this. It was meant for configuration with Streamyx but you can ask your ISP for the required values circled in the pictures.
http://whatidoonmymac.wordpress.com/2009/05/12/d-link-dsl-2640t-wireless-signal-on-but-no-internet/
good luck!
Posted on May 19, 2009
mail2pvs
  • 390 Answers
SOURCE: vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Posted on Jun 24, 2009
kenpem
  • 7 Answers
SOURCE: I'm not able to connect my Lenovo laptop with my
Temporarily connect to the router with a cable and reconfigure it to use a different wireless channel. While you're there, this is a good time to change your security mode - WEP is dangerously weak and you should switch to WPA unless you have a very good reason not to.
If all else fails, there's a reset switch (hidden inside a hole) on the back of the router.
Posted on Oct 12, 2009
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Tip
Find out why and how to work wirelessly, and a few safety precautions
Working wirelessly: What you need to know
Many companies are making the leap to wireless networks in the office for both financial savings in overall equipment and sheer convenience for their employees. They also often provide mobile PCs with wireless capabilities to their employees so that they can be productive anytime anywhere, hence enhancing the company's bottom-line.
In this article, I will explain what WiFi is and how it works. I will also discuss what you need to start working wirelessly as well as what you can expect to gain from doing so. Finally, I'll discuss the precautions you should take when working on the go.
What is WiFi? Learn the lingo
Wireless, or WiFi, technology is another way of connecting your computer to the network using radio frequency and no network cables.
Wireless works similarly to cordless phones; they transmit data from one point to another through radio signals. But wireless technology also requires that you be within the wireless network range area to be able to connect your computer. There are three different types of wireless networks:
* Wireless Local Area Network (WLAN): WLAN are wireless networks that use radio waves. The backbone network usually uses cables, with one or more wireless access points connecting the wireless users to the wired network. The range of a WLAN can be anywhere from a single room to an entire campus.
* Wireless Personal Area Network (WPAN): WPANs are short-range networks that use Bluetooth technology. They are commonly used to interconnect compatible devices near a central location, such as a desk. A WPAN has a typical range of about 30 feet.
* Wireless Wide Area Networks (WWAN): WWANs are created through the use of mobile phone signals typically provided and maintained by specific mobile phone (cellular) service providers. WWANs can provide a way to stay connected even when away from other forms of network access. Also, be aware that additional charges are often associated with the usage of WWANs in some locations.
How do I get started?
The only thing you really need to go wireless (in addition to a mobile PC) is a wireless PC Card. Depending on the age of your mobile PC, the card is either built-in or needs to be inserted in the PC Card slot and includes an antenna. In addition, you can also use wireless keyboards and mice, which can provide more freedom and flexibility when you're working in your office.
It's always good to research the available hotspots in the area you're planning on visiting (whether a neighborhood in your city you're not familiar with or a city on the other coast). You can use Bing to find hotspots when you travel.
As you head out in this brave new world of wirelessly connectivity, you can connect to a wireless network (whether at home, at work, or on the go).
Connect to a wireless network
* Windows 7
* Windows Vista
* Windows XP
Working wirelessly: What's in it for me
Working wirelessly can offer you the following benefits.
* Flexibility: The lack of cables that comes with wireless networking enables you to roam with your mobile PC. You can roam from your office to a nearby conference room for a meeting, or from the couch in the living room to a kitchen for a snack. For example, if you're working wirelessly in a meeting you can printout a report for a co-worker without having to leave the meeting.
* Time-saving: If you're waiting for an important response you can use your mobile PC to monitor your e-mail even when you're in meetings or at lunch. As soon as you get the data needed, you can promptly forward it to your customer rather than wondering whether the information has come in while you were away and having to run back to your office between meetings and other commitments.
* Increased productivity: Working wirelessly enables you to turn down times between meetings or while in transit into productive time. For example, you may be attending a conference and just found out that one of the sessions you were planning on attending has been cancelled. Rather than waste the next hour, you can check e-mail, start compiling your trip report, or order your son's birthday present.
* Easier collaboration: Using wireless mobile PCs, you can easily share files and information with others. For example, you can collaborate on a presentation with colleagues during a flight delay in an airport lounge, or you can share the syllabus of a course while attendees so that they can take more digitally during the class.
What should I worry about when working wirelessly?
When working wirelessly from hotspots and public places, you are responsible for ensuring the security of your files and your mobile PC.
To make network access easier for their users, public hotspots typically leave all security turned off. This means that any information you send from a hotspot is most likely unencrypted, and anyone within range of the wireless LAN, whether at a next table or in the parking lot, can access and use your Internet connection, and look at your unprotected information.
WiFi gives you the freedom to go anywhere and still be connected to your office, your family, and other important aspects of your life. Your virtual office can now be an ice cream parlor in a seaside resort. Embrace and enjoy the flexibility that WiFi affords you.
on Dec 28, 2009 | Computers & Internet
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Internet radio will not connect to recognized WiFi
Try going into your router configuration menu, and opening the network so that any device can connect. Disable any passwords and all of that, and see if it will connect in that way. This doesnt sound like a problem with the Stiletto, rather a problem with the configuration of the wireless router. Maybe call the tech support for the router also.
Dec 19, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Link notebook and desktop pc's both at home and office capable of sharing a printer located at office.
what are you using to configure the wireless????
the process is simple and yet it is complecated to have both wireless configuration.
let me know if you need directions and step-by step.
frcs68@hotmail.com
Oct 17, 2008 | Computers & Internet
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Radio Antenna Adapter for Sirius radio add-on
Brought problem to my trusted auto mechanic and he found a simple disconnect/connect where to antenna cable comes into car under front right side under the glove box. It took literally 30 seconds to do.
Jun 18, 2008 | 2005 Mitsubishi Endeavor
Connet my home pc
obviously, you cannot use a cable to link up from your office network.
1 know your provider and the kind of WAN service offered
2.Get a router that is compatible with your office network and configure your router with similar priorities with that of your officce network(a wireless radio might be require)
or if you are not vast networking,invite a network administrator to do it for u
Apr 14, 2008 | Computers & Internet
My broadband wireless adapter isn't connecting
Hmmmm... this is quite hard endyananna... Is your computer have its own third party Wireless Software? Sometyms Built in adapters on laptops come with their own wireless software that manages the wireless connection. First thing is to locate that program by going to network connections and checking the name of the adapter. Once you found the name, go to the all programs and look for that software there. Try to connect using that software first. In case that it wont work then you have no choice but to use Wireless Zero of Windows. go to run, type services.msc, enable it , start the service, go to network connections, go to wireless cx properties, put a check on use windows to configure my wireless network settings, click ok, right click on wireless network cx, open up view available networks, you should be able to connect after that. In case that it didnt work. Then I have a hunch that youre computer have another software that configures your wireless network connection and that prgram must be used. Good Luck then. If you have any problems, you can always call your OEM for support.
Sep 25, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
