When unit is powered on it just makes a buzzing noise & does nothing else
  • 25 Answers
I'm assuming you have freqencies programmed. If you do you might adjust your squelch key. You are possibily locked in on a dead air frequency transmission.
Posted on Apr 23, 2009
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Apr 25, 2015 | Polaroid FLM-3734B 37 in. LCD HDTV
Computer keeps making loud buzzing then freezes or buzz with black screen
check its not the fan making the noise,
because if its your fan it may not start up.
and make sure its not the power unit buzzing.
let me know how you get on.
Apr 11, 2015 | Acer Aspire 7520-5757 Notebook
BUZZING NOISE
Is this noise a motor buzzing noise? If motor has power but the start circuit is not energized, then the power through the run winding cannot start the motor and may make a buzzing. Need to address the type of buzzing and if the motor, then check motor circuit.
Jan 08, 2014 | Hoover Dryers
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
Buzzing noise
If its doing it when turned off its in the standby power supply inside the unit which runs 7/24 if the unit is plugged to power.
Dec 06, 2012 | Sony DVP-SR200P DVD Player
Unit does not want to turn on. Power to switch, makes a noise when you turn the knob, but machine does nothing?
Sounds like either the unit's control board or timer is not communicating correctly. If you at all hear a humming or buzzing noise, the control board may be having issues with the motor of the unit. You would need a professional in this case to move forward.
Sep 23, 2012 | Frigidaire GLGR642A Gas Dryer
I just bought a Singstar bundle but the mics provide a constant buzzing noise when activated. I've tried different usb hubs and blowing on the ports but didnt work. It is only when the mic's are activated...
We've had the issue since PS3 purchase. I read on another forum today about having plugged the PS3 in the same power extension block as the TV causing the issue. Though this was not the cause of our buzzing on the PS3, it lead me to the fiind the cause of my buzzing noise problem . The issue is caused by use of Power over mains ethernet adapters, in my case these are used to connect my BT Vision unit to the internet. As soon as the unit makes a data connection to it's master unit, the humming starts! We are just going to have to power the nearest adapter off when we wish to make use of the MICs on the PS3!
Jul 29, 2010 | Sony Singstar - PS3
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Ive just purchased a samsung 50 inch plasma which makes a buzzing noise like a fridge. i already had a phillips 42 inch and this made hardly any noise. is this normal as its driving us mad.
This unit should not make a noticable buzz. Bring it back for an exchange. There is a problem with the switch mode power supply.
Dan
May 07, 2008 | Televison & Video
101 people viewed this question
k24674
jasbo
jasbo
