Question about Kenmore 62622 Microwave Oven
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
  • 10,865 Answers
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Posted on Apr 21, 2009
Power will not stay on
its anyones guess without testing..but i know a pwr diode..or magnatron can cause this..its time to replace it
Jan 08, 2014 | GE JVM1650 1000 Watts Microwave Oven
I have a kenmore microwave hood combination. Model 721.80419. How many watts does this microwave work on?
It has a specified power rating of over 1000 watts.
There are 10 settings of power and is prrogramable.
get your manuals from the following link:
http://www.hammerwall.com/Download_Manual/59565/
Sep 18, 2010 | Kenmore 80412 Microwave Oven
My JVM1653 loses power after 3 minutes of heating
it may have been the hi voltage at the magnetron,but the shut down is your heat thermocouple mounted on the magnetron side and when the mag overheats this thermocouple opens up and shuts off power to the mag to prevent overheating and fire
Apr 17, 2010 | GE JVM1650 1000 Watts Microwave Oven
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave display window shows locked!!!!
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may be grease or soot on the control panel causing a lockup, and it may need circuit board cleaning / repair or a new keypad.
Sep 01, 2008 | Microwave Ovens
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
Nothing works on my microwave
When they're totally dead, I would first suspect the internal fuse or the magnetron thermal cutout / thermostat. Most of the time there's a problem that caused the fuse or thermal cutout to blow, but sometimes just replacing that part will fix it. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely much cheaper prices here http://tinyurl.com/gv383 Be safe!
Feb 07, 2007 | Kenmore 63352 / 63359 1100 Watts Microwave...
Kenmore 62622 Microwave Oven Logo
328 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
