Question about Whirlpool LSR6334LQ Top Load Washer
Whirlpool washer model # LXR7244J01
Washer will fill with water and wash but will not go into the spin or rinse cycle. Last month the agitator was fixed. So I'm confuse on what could be going on now.
  • steve
    steve May 11, 2010
    If you move the timer to spin, does it pump and spin?
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
NOTE: If your washer still goes through the normal cycles like it should (i.e., agitates, spins, etc.) and simply won't drain, you may have a drain pump clog, or in the drain lines somewhere. Verify your lid switch, first.
Posted on May 14, 2009
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
Hi there. I can help you.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
Jun 18, 2009 | GE WSXH208A Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool LSR6334LQ Top Load Washer Logo
    428 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
