Question about Sony VAIO VGN-N250E/B Notebook
How to remove the hard drive on a Sony Vaio VGN-N250E
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
Posted on Oct 24, 2008
joecoolvette
  • 5660 Answers
SOURCE: Where is HD on VGN-N250E
It's in the bottom left hand corner, as you view the laptop in it's normal position.
Sony Vaio's are not like other laptops in -> this respect.
With MOST other newer laptop's, you burn to disk your personal documents.
(Anything in your My Documents folder. My Pictures, My Music, My Videos, and personal documents you have created)
Then you buy an inexpensive external enclosure, (2.5" for laptops. And Sata for a laptop like yours), insert the new harddrive, and attach the external enclosure to your laptop, via a USB cable.
Then there is a certain key, or keys, you press on the keypad, and a menu comes up for transferring your Operating System, and programs you have installed, onto the new harddrive.
You remove the AC adapter, (Charger) and the battery.
The new harddrive is then inserted in place of the old one. Access to the harddrive, is usually removing a screw or two, then pulling the harddrive out, with part of the laptop body. Reinstall the battery, and plug the AC adapter back in. Away you go.
With the Sony Vaio series, this is not happening.
You have to use an external enclosure, and a 'mirror' imaging program, like Norton Ghost, Acronis True Image, or DriveImage XML, (Free), and mirror image the operating system, and programs to the new harddrive. (Via the external enclosure)
Then the fun(?) begins.
All electrical sources are removed. The laptop is turned over on it's top cover. Six screws are removed around the outside case edge.
One screw is removed towards the Front, and right next to the Memory Compartment Cover.
The laptop is turned back over, and a small flat tip screwdriver is inserted into slots, in front of the keypad. (Jewelers screwdriver)
The keypad is released and tilted back.
A flat ribbon cable is disconnected, from the motherboard that leads to the keypad. The keypad is removed.
Then, a small White flat ribbon cable is disconnected, in front of the keypad area. This ribbon cable connects the Front panel buttons, to the motherboard.
Now, the Top Cover is popped loose from the Bottom Cover. There is a thin parting line where the two halves meet, and a jewelers flat tip screwdriver, is inserted in this parting line towards the back. (Near the LCD screen) The Top Cover is eased up a bit, on one side, then the other side is eased up a bit. Work towards the front.
When getting to the end, (Front), the Top Cover comes off.
Now the harddrive can be seen. There are Two screws towards the Left side, in the corners. These are removed. There is One
screw towards the Right/Front corner. This is removed. The harddrive has a fabric pull 'tab' on the end of it. This is pulled on and the back end of the hardrive is gently lifted up, as it's pulled back. (Left side of harddrive is the back end)
-> Extreme caution is taken here, as there are tiny metal pins on the front off the harddrive, that can easily be bent!
There is a metal thin frame that goes around the harddrive. This is removed, by removing Two screws on each side. The metal frame goes on the new harddrive.
Posted on Apr 18, 2009
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Disk drive will not read on my sony vgn-n250e
Its looking like the error in ur registry so fix ur registry error using reginout registry cleaner
Aug 31, 2010 | Sony VAIO VGN-N250E/B Notebook
Sony VAIO VGN-250E/B upgrade memorey, will it take up too 4gb?
No the Sony VAIO VGN-250E/B has a maximum capacity of 2GB DDR2 RAM.
Oct 13, 2009 | Sony VAIO VGN-N250E/B Notebook
Problems booting Sony Vaio VGN N250E
no more then likely it sounds as tho your hard drive went ..not the mother board.
Jul 23, 2009 | Sony VAIO VGN-N250E/B Notebook
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
Can Sony VGN use single memory module?
You're gonna need two 1gb modules.
Hope this helps.
Best of luck!
Feb 28, 2009 | Sony VAIO VGN-N250E/B Notebook
Sony vaio vgn-n250e laptop microphone problem
Good Luck.
Oct 24, 2008 | Sony VAIO VGN-N250E/B Notebook
Sony VAIO VGN-N250E/B Notebook Logo
451 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
