Question about Sony Playstation 3 (PS3) Console
How do we change PS3 settings from HDMI back to non HD?
PS3 was working fine then we went to visit friends with a HD telly and set it up for HD. Now back home we cannot get the PS3 to work on our non HD telly. Can anyone help please?
    Sniper:
  • 79 Answers
Switch it to standby then hold the power button for three beeps(not including the first power on beep)this should open a troubleshooting menu,pick option 2.If it doesnt give you the menu first time,switch it off at the back and repeat the steps again.Good luck.
Posted on Apr 21, 2009
  • wyrmm1 Feb 03, 2011
    solved my issues, very easy. TY
MY PS3 is hooked up via HDMI and has always worked fine. All of a sudden i went to turn it on and there was nothing but black, it detected a signal, but it was just black.
Hi there, Have you switched cables or changed any of the video output settings on the ps3 or your telly? Just double check all the settings and that the cables are connected properly and are not damaged. If you have another cable try that to see if you still have a black screen or try on another telly with the same cable to see if it's the cable that the problem is? If you using a standard cable to try on another tv, you will have to reset the video output so it will work, to do this simply hold down the power button on the front of the ps3 until it powers off again and this will allow it work on a standard tv with standard cable, and to switch back to hdmi just connect with hdmi. Cable to HDTV and the ps3 will detect the cable and ask if you want to use these settings. Hope this helps
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
My plastation 3 works when i hook it up through the hdmi cable but not the regular cables that come with the consol. is there a setting i need to change?the cables are not broken nor are the hookups on my...
Ok, you need to reset the PS3 back to standard video settings by doing the following :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the display to initialize.
Hope this helps
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
MY SCREEN IS BLANK MY TV IS NON HDMI AND SO WAS
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
PS3 not showing up anywhere.
yeah had the same prob when i wanted to play on a mates non hdmi telly.. but its simple really connect everything up then switch on hold the powers for 5 seconds this resets the connection settings from Hidef to standard ..easy peasy..... was workin fine. but mine is sayin cannot start, the correct hard disk was not found any 1 any ideas?
Nov 01, 2008 | Sony Playstation 3 (PS3) Console
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
621 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
