Av doesnt work
I cant get any picture from my xbox on this old diamond vision tv is there a way to reset the tv or something.
  • 21 Answers
No but what you can do is use a converter adapter that converts rca signals to rf signals also known as antenna or cable plugin good luck
Posted on Aug 03, 2009
Tv diamond vision code
025,029,024,009,000 are the codes to check. If you wish to get more, check this link. http://schematicscom.blogspot.com/
Oct 08, 2013 | Jensen Televison & Video
Cant see anything but you can hear it
it is most likely your tv, try using a different tv to test or i could be av leads, try new leads if its not the tv. some old tvs get loose plugs so the sound may work without the picture or vice versa.
hope this helps
Nov 28, 2010 | Microsoft Xbox 360 Console
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
I have also tried the xbox on different televisions
as the console starts
press and hold the y button for 2 sec
then pull the right trigger but dont release the y button..
if your successfull, the console should restart..do it a couple of more times...
what you are doing is trying to reset the display to defaults
Jun 27, 2009 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Can only get snow on tv screen
Try Changing the AV cable from HDTV to normal TV unless your TV is HD the cable Setting on HDTV will not work. You have to turn off the system and then change the switch. Then turn on your system.
If this doesnt fix your problem then Either of two things has happend your AV cable has gone bad or the chip that enables the AV cord inside the XBOX has bit the dust. If this is the case you will need to contact MS.
Jun 06, 2008 | Microsoft Xbox 360 Console
Bad connection?
Cant get picture, sound working. new cables has 5 plugs
Feb 23, 2008 | Microsoft Xbox 360 Console
Diamond Vision TV/Remote
SOLUTION: I had the same problem with a Diamondvision DTV3913. After trying many universal remote controls, I found one that worked. The RCA universal remote CRCR3273 / CRCR3373 (also referred to as RCR3273 / RCR3373) was the answer. It has 3 codes (1232, 1233,1234) for DiamondVision TVs and the first one worked. It gives me all the control I needed including the hard to get ones like input selection, main setup menu etc. It also has codes for DiamondVision DVD players and VCRs. I see it at BestBuy for $8.
Jan 10, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Jvc model av-56wp74
Needs convergence IC's replaced..........T.
Oct 06, 2007 | JVC AV-27850 27" TV
Tv/dvd
Try ordrer the original remote contrl by Tv's manufactory. Aleixo
Sep 04, 2007 | Toshiba MD20FM1 20 in. TV/DVD Combo
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
