Question about GoVideo Go Video DVD/VCR Combo
GoVideo VR3840 will not Finalize
GoVideo VR3840 will not complete it's Disc Finalize...all numbers minute and seconds go to zero on monitor but will not finish.
  • GoVideo Master
  • 3,866 Answers
Clean the laser unit by using a cleaning DVD. This should shore up the problem if it don't try using another brand of Disc maybe you had got a bad batch.
Posted on Apr 21, 2009
About 5 years ago I transfered some vhs tapes to dvd using a go video vr 3840. I did not finalize the dvd's. I need to buy another vr 3840 to finalize the dvd's. Where can I find one to buy?
You should not need another '3840 to finalize the disks. Finalization just ends the index, makes writing back to the disk near impossible. You should be able to finalize / close the disk using a dvd authoring program (Nero, CD BurnerXP, etc).
The catch may be that the disks that you created are formatted as DVD video, closing a video disk may not be the same.
Another possibility is to use an authoring program (like the above) to copy your un-finalized disks to fresh media, and specify the disks to be finalized (or closed) when completed. I would try this first, the only thing to lose is time, and a disk. Oh, and about 4.7GB of hard disk space to create the image if you only have 1 DVD drive.
Jun 29, 2010 | GoVideo Go Video VR3840 DVD Recorder/VCR
My computer says a finalized dvd made on govideo vr3930 is blank.
Sounds like your computer only reads certain disc's like dvd-r or dvd+r check to see if the burned disc is the same as the original? Second Could be that you really did not finalize? good luck, safety first..
Mar 09, 2009 | GoVideo VR3930 DVD Player/VCR
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
DVD unable to play tv recorded items
If you can see recording on the flip side..it is either a disc patch fix (software) obtained thru Go Video..or find another go video recorder to finalize it..you might try unplugging the unit for a minute or two..and try it again...
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
Initalizing DVD-Rs
are you using a quality brand of dvd-r like memorex.
Also after making a recording you must finalize the disc you recorded so it will play on other players.
Jan 08, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
Go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Dec 25, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
109 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
