Question about Dishwashers
Grinding noise in dishwasher. 4 day after warranty..Can I fix it myself...Need your help... Thank You, Sandi
    Brigadier General:
  • 8,619 Answers
Hi
Grinding noise is due to a cracked impeller which can be accessed by removing the spray arm. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Aug 14, 2014 | Frigidaire Professional Series 24 in....
Washing maching grinding during spin
these side load washers are a joke, and after working on my first one, seeing what a bad design they are. I would junk it and get a top load. but hey if it's still under warranty have it fixed. LOOK it might have a recall also ? search the model number.. I myself wouldn't spend a dime on one of the stinky, smelly pos's good luck.
Jay the pool pump motor repair guy in longwood Florida
remember to thumbs up. thanks.. J
Feb 08, 2014 | Washing Machines
My old kenmore electric dryer is making a loud noise when it is drying. the model number is 96195100. i want to try to fix it myself if it is worth fixing. PLEASE help!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 28, 2011 | Dryers
Samsung DMR78 dishwasher makes a grinding noise at the beginning of the wash cycle as well as the rinse cycle. Also comes up with the code 9E on occasion.
Check the brackets that hold the top rack for any broken plastic brackets. My dishwasher was making the same noise and after noticing the broken plastic pieces I pulled out the dishwasher put it on its side removed a white panel on the bottom that is attached with two screws, removed the drain line and inside there were two plastic tabs from the broken bracket. Once those were removed the grinding noise stopped. The bracket holding the drain hose can be removed with a pair of pliers.
Jan 01, 2011 | Samsung DMR78AHS Builtin Dishwasher
Hi! My dryer was running just fine when it started making a loud noise. I turned it off and tried to resolve the issue, but I believe that it came off track. Is there a way to fix this myself with out...
heatman101
Nov 10, 2010 | Kenmore Dryers
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Focus front brake grinding noise on frist braking in the mornring
Look for a metal tab at the brake. It's only supposed to touch (and make noise) when the brakes are worn down. Sounds like it's bent in too far.
Mar 25, 2009 | 2005 Ford Focus
Kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Dishwashers Logo
256 people viewed this question
Top Dishwashers Experts
