Hi! i've been gifted a proview pro758 monitor to connect to my hp pavilion. connected to computer, plugged in power and little green light on power box tells me power is on... but screen doesn't turn on? what did i do wrong? help is GREATLY APPRECIATED!!!
12 VDC , 4.16 A (4,16 A)
Frequency: 50/60 Hz
Power Consumption: less than
36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Ensure the video cable is connected (and connected to the correct video port).
Turn off the monitor using the monitor's power button and then restart the monitor.
Cycle the power on the monitor as follows:
Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
Unplug the power cord.
Wait 5 seconds.
Plug in the power cord.
Press the power button on the monitor to turn on the monitor.
One of two things happens:
The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
