Question about Microsoft Xbox 360 Console
Xbox 360 my xbox 360 has pack up it has no picture yesterday the picture was going yellow green had the xbox two years now can you help
    Novelist:
  • 174 Answers
This is due to overheating and the mainboard warps, because of this the lead free solder cracks and causes exactly the problems you are describing. the machine is quite an old one and this is a common fault, we can get the machine back to normal again for you for £40 which includes return delivery.
We reflow the mainboard which in turn re-seats all of the lead free solder recifying any problems. We add heat conducting pads to the memory chips and we totally replace the X-clamps because the design is a flawed one.
All of this is covered in the price.
www.fixmyconsole.co.uk
Posted on Apr 21, 2009
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
3 red lights, but nothing turns on
sorry to say that is the Red ring of death your gonna have to send it to microsoft and they will repair it for free
Jun 14, 2009 | Microsoft Xbox 360 Console
No video or sound.
This is usually caused by a bad graphics card on the xbox. It isn't always detected by the xbox motherboard. I'm sorry to say, but it's pretty much toast unless you can find a repair guy in your area to solder on a new vga card.
May 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
