Control the volume on each of the 12 bass shakers i plan to install
I need to wire 12 bass shakers to my amp and control the output on each shaker
    Sniper:
  • 86 Answers
Please note that you can't simply wire them together in series or parallel. Connecting any more than 2 would likely cause damage to your amplifier. (depending on the impedance of the bass shaker 4 ohms, 8 ohms, etc.)
The Buttkicker brand recommends the following configuration for four buttkickers into one amp: Click here
As you can see, you need a combination of parallel and series connections to make sure the amp is "seeing" the correct load. I'd recommend purchasing three dedicated subwoofer amps (there are some good inexpensive ones at http://www.parts-express.com.
This will give you volume control over each set of four shakers at the amp itself. If you need control at each shaker, the only solution I know if is to use an impedance matching volume control.
Check Parts Express for those, too.
If this solved your problem, please rate it as FixYa. If not, let me know how else I can help you.
Posted on Apr 21, 2009
Is there a book that teaches you how to create (wood) salt & pepper shakers?
urning Salt & Pepper Shakers and Mills
73l0522s01.jpgby Chris West
May 09, 2013 | Home
Replaced SD card now Shaker won't play
Hi Cathi!
Few things you need to know about Sansa Shaker and the SD card:
  1. The Sansa Shaker DOES NOT support SDHC memory cards. Only regular SD cards are supported.
  2. Maximum capacity for supported SD cards - 2GB!
  3. Any SD card which doesn't meet the requirement above might cause the problem you encounter. REPLACE the card with a supported one - SD card with up to 2GB in capacity.
  4. No software/data is stored or needed to be on the memory card - apart from your music files.
  5. MP3 file type is fully supported by Sansa Shaker.
Regards,
Pelu.
Apr 10, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Adding amp and speaker, no rca amp jacks on back of radio
well you can installl anything you want into your vehicle you just need to know how!!
Apr 14, 2009 | Car Audio & Video
My shaker does not play all of the loaded songs.
I had the same problem. The songs that won't play are probably MP4 files and the shaker only plays MP3 files. You need to change the file format of the songs on the shaker to MP3 files. I downloaded "Media Coder" which was free and it converted all the songs on the shaker that wouldn't play to MP3 files and they play now. Google "Media Coder" and download the free program, it is very easy to use. I had the songs converted in about 2 minutes. Make sure the shaker is plugged into computer so that you can choose the files on the shaker to convert. Hope this helps.
Dec 23, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Can't download any music onto my sansa shaker
ITunes songs are not in MP3 format.
The Shaker will only play MP3s
Dec 29, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Eclipse PA5532
I do think you can knowing your Amp is 5channel and 960watts,Yes you can goto radio shack for the potentimeter or goto your local audio store and buy a equalizer So you don't over power your Amp
Nov 22, 2007 | Eclipse PA5532 Car Audio Amplifier
Sansa shaer
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Nov 15, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
"uh oh"
The music has to be in MP3 format.
If you have copied CD's to your computer, you will need to change the settings in Windows Media Player to copy them as MP3's.
Windows Media Player>Tools>Settings>Rip Music (Copy Music)>Chane Rip Music as to MP3.
Delete all the songs you copied before from your computer and from the Shaker.
Copy the new songs back to the Shaker after you change the settings.
Best of Luck.
Oct 16, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Open Questions:
83 people viewed this question
 Grubhead
Grubhead
