Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
My kenmore dishwasher wont pump water in to it
  • 234 Answers
If your water supply is good to the unit, then the problem is most likely the water inlet valve. This is a common problem and they are not very expensive (under $40.00).
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
Dishwasher wont fill all the way up
You have to remove the bottom panel of the Dishwasher to get the problem solved. For More information please visit Ice Machine Cleaner.
Oct 04, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Wont pump out water
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Feb 09, 2011 | Kenmore Dishwashers
My kenmore 665.13719k600,wont clean the dishes
Try cleaning your dishwasher using a dishwasher cleaner. this will clean out the build up. There is one that i recommend and it is called Dishwasher Magic.
You can prevent this from occurring in the future by, installing a Water softener in you home. this will heel the build up.
Jun 19, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Apr 18, 2009 | Kenmore 15762 Dishwasher
No water
inlet solenoid not working, check wiring is attached
Jan 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 16182 / 16189 Built-in Dishwasher
dedra, you should call for factory service on this so you don't void the warranty. You could have a couple of things going on here. If your model starts with 587, you have a seperate drain pump on this model. The impeller in the pump could be jammed with something or the control module might not be sending power to the pump. The fact that it operated normally the first two times you used it leads me to believe that the drain lines are ok. I have found debris caught in the impellers from the factory on some of these new 587's. Best to call for service, all costs are covered...Catriver..post back.
Apr 16, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Kenmore dishwasher
fatubu, are you sure you have the correct model number, Im not finding anything on the posted model. They had an issue on models close to this that had an issue with a twisted or missing seal in the pump assy. causing water to fill the pressure switch hose. The dishwasher would drain water after the fill. The fix was to replace the pump and motor assy. Catriver..post back.
Feb 18, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
191 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
