Question about Canon imageRUNNER 400S Copier
Same problem Error shwong first closed the front door then E-805 errror then wer is the problem we cant understand
    Sniper:
  • 67 Answers
There is a fan that quit working.
Posted on Apr 21, 2009
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Ir 400 error 805 002
Your connector is not good is connected to the DC control board. That connector is J112, which is located in top 3 of left to write.
Jun 12, 2012 | Canon imageRUNNER 400S Copier
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
10.92 errror message. I have install a new black cartridge but the message keep telling me to close the door. HELP PLEASE. THAQNKSw
10.92.XX says that the print cartridge XX(00=black, 01=cyan, 02=magenta, 03=yellow) is not engaged correctly.
Since the error occurred after replacing the black cartridge, it's a good bet that the black is bad.
Put the old black in the printer and see if the error goes away.
Open and close the front door slowly and look at the cartridges. You should see the cartridge flaps all open and close as you open and close the front door.
If the flaps don't all open and close, the cartridge lock mechanism could be broken.
You can run the DISABLE CARTRIDGE CHECK diagnostic. This will allow you to remove all the cartridges and install all or one in any slot you want. In your case remove them all and put the cyan in the black slot and see if the error goes away. If yes, put the black in any empty slot. If the error returns, the black is definitely bad.
Apr 18, 2011 | HP LaserJet 3600n Printer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Lexmark E 250 dn printer. Keeps turning off. Switching from blue bulb indicator to exclamation point indiator. Difficult to turn back on by pressing blue arrow button
The problem could be several things, the first one could be a Flushing buffer error. That means that the printer did not understand the print job sent to it and has to be reset in order to continue printing. Second could be a memory full error where the print job sent to the printer is too big and the printer memory is not enough. The third could be the printer front door is not closing properly, make sure the toner cartridge is installed correctly and that the front door is closed. That's all I can think of right now.
Jan 12, 2010 | Lexmark E250dn Laser Printer
Error "close front cover"
make sure the protrusion that activates the switch telling the machine that the door is closed is not damaged.
Apr 02, 2009 | Ricoh Aficio 1018 Printer
Close the front door and second problem is E805
805 is a bad fan usually one of the three on the exit door
Dec 10, 2008 | Canon imageRUNNER 400S Copier
Door latch
DE error code is because there is a drain problem and it will not lock the door.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Maytag front loader door will not open
try pause/cancel twice to open door open detergent disp look for a plastic string and pull it
Dec 31, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Canon imageRUNNER 400S Copier Logo
old marine
old marine
