Question about Compaq A1000 InkJet Printer
Can't install compaqA1000 all in one
I have a dell optiplex170L and compaqA1000 all in one printer and i can't install. Give and error:insufficient software. The comp. recognize printer A1000 but went i do the setup.another error :we not install because printer is not connect
  • darlenep Aug 14, 2008
    i have a hp computer with a compaq a1000 pinter. i cant install printer on the computer. do not have a disc
    President:
  • Compaq Master
  • 2,022 Answers
First you unplug the usb cable restart your system and then install the drive software first and then connect the usb cable to the sytem and make sure ther is no other device in your device manager which is showing yellow exclamation mark if it is thre remove that. you can go to device manager by reight click on my computer go to properties and the hardware then device manager tab.
Posted on Sep 22, 2007
SOURCE:
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Dell optiplex170L set up wifi
well I guess you have OS. Windows 7,but any way you can go to download this tool and they fix for you any problem NetAdapter Repair All In One Download
Sep 27, 2014 | Computers & Internet
Spl-c error insufficient memory
Insufficient memory seems to be caused by printing large, complex images. Printing slightly smaller will often fix the problem.
Mar 05, 2013 | Samsung CLP365W Color Laser Printer
Hp 5100 insufficient memory error
Does it always happen? does it always happen from a particular program? may need to upgrade your memory capacity.
Dec 21, 2012 | HP LaserJet 5100 Printer
My hp printer m1005 show error 20 and some time error 17. Plz. give me solution.
A 20 error is insufficient memory.
The device received more data than can fit
in the available memory. You might have
tried to transfer too many macros, soft
fonts, or complex graphics.
Touch OK to print the transferred data
(some data might be lost), and then simplify
the print job or install additional memory.
As for the 17 error?...I can't find it in the manual.
Feb 13, 2011 | HP LaserJet M1005 Printer
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Compaqa1000 need disk to install on new computer
open link and download driver .......
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=216824&cc=us&lc=en&dlc=en&product=216824&dlc=en&lang=en
Apr 06, 2009 | Compaq A1000 InkJet Printer
I can not uninstall my PrintMaster Gold 16
your computer is being a pig. dont worry about uninstalling your printer, just add another printer and make this one the default printer. you can just ignore the other one...........shimple.
Mar 10, 2009 | Broderbund PrintMaster Gold 16 for PC
Hard drive
If you look at the hard drive inside your computer, there will be 2 cables plugged into it. If one of the cables is a flat cable about 2 inches wide, then its IDE interface type.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Sep 05, 2008 | Dell OptiPlex 170L PC Desktop
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Jan 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Open Questions:
See all Compaq A1000 InkJet Printer Questions
Compaq A1000 InkJet Printer Logo
168 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
