Is there a way to MUTE while speaking through this phone set - Panasonic KX-TG2583B. Can you please respond to my ID [email protected]
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
SOURCE: can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep. Repeat if you want mute again.
Jack
SOURCE: No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
