Question about Windchaser PACR10 Portable Air Conditioner
It's leaking water - Windchaser PACR10 Portable Air Conditioner
  • mcbear1 May 11, 2010
    where is the inlet tube
    Genius:
  • 1,550 Answers
The will be leaking only at the inlet
of the water to your machine
check the inlet tube in your machine
Posted on Apr 21, 2009
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
How can I find the water leak in my Great Lakes Spa
turn system off let water settle get pheno red or leak detector squirt carefully by each spa jet if color goes to that area it could be leak i need more info was this spa winterized if so take sides off look for the water you might have to dig the insulation away to acually find leak usually it is plastic couplers
Jun 07, 2014 | Jacuzzi Balboa R574 System for 1 2 Speed...
Ge smart water heater
Depends on source of leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Leaking-water-heater.html
Some leaks can be repaired, while other leaks indicate that tank is rusted and needs replacement.
Gene
h
Aug 10, 2013 | Water Heaters
Leaking water from top
1) Copy following link for troubleshooting leaking water heater:
2) After opening link to identify problem, add a comment and give brand, type and approx age of waTer heater for more possible help.
Feb 19, 2013 | Water Heaters
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Why is there a water leak coming from the water pump?
i would say you answered your own question, if there is water leaking from the water pump i would say the water pump is leaking and it needs to be replced,either the bearing is bad and its leaking out the shaft,or the seal is bad and its leaking outta there either way you need a new water pump,check the belt for wear when you replace it,,
Oct 07, 2009 | 1998 Dodge Caravan
Windchaser PACR10 Portable Air Conditioner Logo
369 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
