Question about Whirlpool GR460 Electric Kitchen Range
Oven wont unlock after self clean cycle
After cleaning cycle oven still locked. previously would not keep proper oven temp when baking. unplug and resetting wont release oven door.
    Genius:
  • 1,198 Answers
Make sure you're getting 220 to the stove, maybe one breaker is off or bad.
Posted on Apr 25, 2009
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
How to unlock oven Door frigidaire?
Usually the door locks during a self cleaning cycle for safety reasons. If the self cleaning cycle did not finish properly (over temp sensor trip, etc.) it could end up with the lock deployed or it could be that the locking mechanism failed in the lock position (unlikely!). Turn off the power to the oven by finding the correct circuit breaker in your electrical distribution box. Keep it off for some 30 seconds. If the oven is ok it will reset and unlock the door. If it has a failure in the locking mechanism you should be able to access that part from the top or you may have to call a repair person. Hope this helps!
Jan 20, 2016 | Ovens
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I can't stop cleaning!!!
I had the same problem. The issue is in the electric switch that tells the oven whether the door lock is latched. If the switch gets stuck in the "clean" position, even though the lock is released, the oven will not run the regular cycles. If you wiggle the lock levr a few times it may free the switch, otherwise you'll have to raise the cooktop, and there is a metal cover over the mechanism. Remove the 2 screws holding the switch (unplug the power first) and you should be able to un-stick it. Reassemble and you're good to go, at least until you need to run the cleaning cycle again...
Feb 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GR460 Electric Kitchen Range Logo
238 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
