NEED CODE FOR REMOTE CONTROL TO WORK WITH TV
I have a lg lcd tv model 37LC2D. the remote just stopped working with it. any idea about the code to be used to set up the connection?
  • 65 Answers
If this is an original remote u should not need a code. You need to find out if the remote is transmitting a signal. If it is a universal remote use your manual to find correct code, use code search or go on internet & look up code.
Posted on Apr 21, 2009
Can I have code list for LG tv my remote stop working but I have a universal remote rm 101 code without code list
It is better to buy a remote for your specific set.
LG Remote Controllers ' LG Canada Parts
https://www.lgcanadaparts.com/catalog/LG-Remote-Controllers
  1. Cached
Authorized LG parts distributor of LG Remote Controllers. Save money on genuine OEM LG parts. ... LG TV LCD Remote Control · Available Online, $ 32.65 ea.
LG Parts & Accessories ' LG Canada - LG.com
www.lg.com/ca_en/support/parts-accessories
  1. Cached
LG Parts & Accessories : Find genuine parts and accessories for your LG products.
LG TV Remote Controls ' LG Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/LG/Remote-Controls/
  1. Cached
Here at Replacement Remotes, we provide you with a large selection of premium LG remote control units for sale, purposed for a great variety of appliances.
Brand Code KURAZAI 0001 LASONIC 0210 0948 LG 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156 LIQUIDVIDEO 0177 0168 0921
universal remote code LG - Google Search
Jan 22, 2017 | LG Televison & Video
"I have LG 37LC2D TV,when I turn the power on remote controlled or manually it immediately powers off. Is this an issue with the on/off switch inside the tv and how can remedy the problem?"
I have an LG as well.
My troublshooing says:
"Check the power control setting.The power supply may be interupted.
Check if the Auto sleep feature is actiated in the Time settings.
Refer to the " Sleep timer".
If there is no signal while the TV is on, the TV will turn off automatically after 15 miutes or so"
Feb 24, 2012 | LG 37LC2D Television
Need the prizmo tv codes for a universal remote
Prizmo TV no universal remote codes work. I called RC Willey (where I purchased the Prizmo TV) to get a replacement remote for my Prizmo 19" TV. Customer service finally gave me a number for Red Rock Sourcing 1-702-252-5049. Red Rock took my Prizmo TV model number and they apologized for any inconvience. I told them no universal remote codes work for the Prizmo TV. Red Rock Sourcing is sending me a free replacement Prizmo remote by Fed-Ex. I hope this helps you.
Aug 14, 2010 | Uniden WHAMx4 LCD Remote Control
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
My LG37LC2D-UD's remote control stopped working.I tested it on another exact same tv and it worked fine. That set's remote would not work my tv. I now know the ir receiver on my set is faulty. I found a...
For Eastern US customers, LG parts distributor is:
Vance Baldwin Electronics
1655 Lakes Parkway NW
Lawrenceville, GA 30043-5858
P (954) 723-9191 (800) 432-8542
F (678) 377-7599
You can also check if it is in-stock in this address:
9201 Penn Ave S.
Suite 40 Bloomington, MN 55431 Work (952) 881-6492 Toll Free (877) 881-6492 Fax (952) 884-5028
Jan 01, 2010 | LG 37LC2D Television
My remote control doesn't work for lg tv model # 37lc2d
have you tried and see if the led is flashing wile looking through a camera on a mobile phone ? this will tell if the remote is faulty.
if its not flashing then open up remote and look for bad joints/connections etc.
the most common is around the led sender and the xtal unit.
Sep 07, 2009 | LG 37LC2D Television
Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Jul 05, 2009 | LG 37LC2D Television
I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG 37LC7D 37 in. LCD HDTV
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
LG RZ17LZ40 remote control code
I have got the RZ17LZ40 tv from LG and just got my new Sky Plus remote Rev.8 to control the tv by using code 0206.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
