Question about Compaq FP 7317 17" LCD Monitor
Reddish hue on monitor
On the bottom of the monitor there are three buttons. I pressed the middle one which caused my cpu to get this red hue, esp. when i'm watching videos. How do I reverse what I just did? And what do those buttons down there do?
    President:
  • Compaq Master
  • 2,022 Answers
Just switch it off and swith it on
Posted on Sep 25, 2007
Where can I find my AOSS button on my Linksys router
What model?Push the Cisco logo to start SecureEasySetup The logo is lit with a reddish hue (the User Guide says this is orange) when the router powers up in its factory default unsecured state. The instructions say to press the SES button. But there is an approximately 8 second pause between the button push and three seconds of no light, followed by the rapid white flashing backlight that indicates the router is in SES search mode.
Jan 25, 2013 | Linksys Computers & Internet
Hi, Have an Advent 7081 laptop. At times screen is either very dim or black ,suspect inverter ,what is your opinion
Probably the inverter. Have you ever seen like a hint of red color or a reddish hue on the screen? I would start with the inverter either way, it should be easy and cheap to fix and it usually is the cause.
Apr 02, 2010 | Computers & Internet
Pink Hue on my Princeton Moniter
If you have access to another monitor, check it with your computer. Pink or red hues are usually indicators of a failing backlight bulb or ccfl bulb that sits in the bottom of the display and lights up the lcd.
Nov 27, 2009 | Princeton Digital Computers & Internet
GA-EP35-DS4 motherboard does not load
is it in warranty..?? if not..
do it if u r a professional..
check the following:
1) the cmos battery (above +3v)..replace with a standby n see..
2) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
3) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
4) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
5) ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
..plz give higher priority to step3 & 4 (as listed above) CAREFULLY..
immediately contact ur system admin/vendor....
Nov 07, 2009 | Gigabyte GA-EP35-DS4, LGA775, Intel P35,...
REDDISH Screen with Samsung Monitor
You should changes the connections first!!!
Monitor connected directly to TV/ CPU without passing the projector unit.
I think that's the problems!!!
Dec 19, 2008 | LG Flatron F700B 17" CRT Monitor
Appearance on monitor is reddish in appearance
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Aug 10, 2008 | Hyundai L90D+ 19" LCD Monitor
Loss of brightness and red hue
I would need the model number in order to even begin to suggest a possible cause.
Jun 26, 2008 | Televison & Video
Reddishness in the screen
Have you loaded the drivers which came with the monitor. This will probably allow you to change the settings.
Right click on an area of your desktop and choose properties. Look at the monitor and make sure the resolution is set to the recommended level possibily between 60 or 75 dependant on the model. Also you can get to the display card settings here and change them to suit. Dont get carried away or you can make it so that you cant see whats on the screen at all to be able to change it. Could also be that your monitor is faulty. Check with your manufacturer. It its an old telly type monitor maybe one of the "guns" have gone so you dont get the right colour mix of red green and blue. If this is the case you will need to get a new screen.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
Compaq FP 7317 17" LCD Monitor Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
