Question about Frymaster Dean 2424G Deep Fryer
Dean gas deep fryer m# SR142GN
Heats up to temp then whole thing shutts off
have to wait about three minutes to turn pilot back on
  • 1,140 Answers
Thermocouple is getting weak. Replace the thermocouple with a new part.
Posted on Aug 29, 2015
burzerko
  • 254 Answers
SOURCE: dean gas deep fryer m# sr142gn less then 2 years old
Yes by what you are describing the thermostat is the only device that would cause this problem.
Posted on Jun 15, 2008
burzerko
  • 254 Answers
SOURCE: pilot light is lite.
This problem is caused by a faulty gas valve.
Thank you
Posted on Aug 28, 2008
SOURCE: dean deep fryer
need to change from natural to propain sr42 g
Posted on Sep 29, 2008
SOURCE: pilot light not staying on
Has the hi-limit been checked?
Posted on Nov 19, 2008
bigg t
  • 640 Answers
SOURCE: we have a dean deep fryer model SR42GNS on start
is the fryer propane or natrual gas?It sounds like the orfices,burners or baffles may be clogged and needs cleaning.let me know.
Posted on Apr 09, 2009
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Pilot lights however when I turn the temp up to where I want it set to pilot goes out. The thermostat makes a ckicking sound when I tune it right before pilot goes out
Hi there.
Verify if the gas pressure fed to the fryer is correct. Check also for errors/ loose wire connections on gas valve, thermostat and hi limit, last possible cause, the thermopile is weak and cannot give enough power to energize pilot and main valve at the same time.
Regards.
Aug 14, 2013 | Dean SR14E Deep Fryer
I have a Dean Model. SR142GN Fryer, I'm having a problem with the pilot. It will light, and stay on, when I turn the gas up it acts like it is supposed to, but after about 2-3 Mins it shuts off including...
Hi there.
Try cleaning the thermopile, it should be free of soot or any form of dirt. Make also sure that the gas supply is at rated pressure and type (as written on nameplate) and all wiring connections must be tight.
Regards.
Feb 05, 2011 | Kitchen Appliances - Others
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Dean #SR142GN fryer want to convert to LP Can we
give me a shout at capt_rick1912@yahoo.com
I have the part #'s you need & prices and would be able to get that out to you asap.
captrick
Jul 17, 2009 | Kitchen Appliances - Others
Gas igniter kit
It could be converted by a qualifed kitchen mechanic. Here is a list of parts for your unit, and supplier.
http://www.a1service.com/dean/deanburner.htm
Sep 03, 2008 | Dean SM20G2 Deep Fryer
DEAN SR142GPS Flame Issue
A gas valve is actually 2 valves in one. The first is your pilot valve, when the pilot is lit, the flame heats a thermocouple or thermopile & that heat produces a millivolt signal that is sent to main gas valve( second part) & tells it that pilot is established and to open to allow main burners to light. The 3 "little flames" were coming from the orfices on the burner manifold. If you are absolutely sure you put the gas valve back in the same direction as it came out (arrow on bottom of valve pointing to the fryer/burners) & any springs or adjustment screws were not mucked with, then there is a malfunction in the gas valve. It needs to be replaced.
Jul 24, 2008 | Kitchen Appliances - Others
Dean gas deep fryer m# sr142gn less then 2 years old
Jun 14, 2008 | Kitchen Appliances - Others
Frymaster Dean 2424G Deep Fryer Logo
503 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
