Question about Canon PowerShot SD600 Digital Camera
Not switching on the device
I was surprized as i put the battary after its get charged, now its not swithing on. Every this seams fine. Dont know the root cause. Can you pls let me know the cause?
  • jes50 Nov 25, 2007
    camera wont switch on the blue light for printing is comming on andlet me do anything on the camera make is ixy digital 2000 is just four week old thanks jess
    Genius:
  • 2,985 Answers
Try a fresh battery in case batter failed. If still no good then contact Canon
Posted on Sep 22, 2007
SOURCE:
AC adapter fine also battary fine but HP 4420s dont charging
If that is true the charging circuits on the motherboard will be the problem, "a rare situation" so long as the laptop powers up using the adapter and the charging voltages are missing in the computer terminal where the battery plugs in then this would apply.
Apr 04, 2012 | HEWLETT-PACKARD HP ProBook 4420s Notebook...
I have a craftsman LT 1000 lawn mower that runs the battery down while it sits and it will not charge the battery while mowing even though the guage says that it is charging.
Something within the machine is discharging the battary, it does not sound like the engine is not charging, there is a tool called a negative shunt, it connects to the negative pole on the battary and enables you to connect a multi meter, this will tell you if there is a charge going out of the battary when the machine is switched off, you can then disconnect components to see which one is causeing the problem, a good mower shop should have such a tool .
Mar 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
Will a faulty ignition switch stop the battary from charging.alternator,r/r,battary are all fine.Its a 955i triumph sprint st and the year is 1998
A guess. If you are running on "start" you might not be charging. But then, if you are running on "Start" I would suspect the starter would also be running. You didnt say this was the problem.
Is your battery going dead? Your alternator is putting out? Check the rectifier.
Sep 07, 2009 | 2000 Triumph Sprint ST
LG Vu C920 automatically switches off while charging
i know this sucks but you may need a new battary.
Apr 13, 2009 | LG Vu CU920 Cellular Phone
HP dv2000 gone dead
the problem occord when the battary charge full somtimes... try to switch on the laptop with battary power (if u getting the beep its k) wait for 10min and swith off the lap n turn it on.. this may work some laptops... when the battary get 100% charge the error beep will *** up... try 2 turn on the lap above 80%....
thanks
Mar 30, 2009 | HP Pavilion dv2000t Notebook
My nokia5800 swithing off alone...
its abug better u format it by pressin *#7370#
pw:12345
Mar 09, 2009 | Nokia 5800 XpressMusic Smartphone
Drill causes my Battary to smoke & Burn out
Do you have more than one battery and if so do they both do this? It sounds like the batery has shorted out or possibly the switch is malfunctioning and creating the short either way I would not try and recharge a battery that has these symptoms. I actually had a NiCad battery catch on fire when I charged it not knowing the history of battery. There are repair centers that usually won't charge you to check batterys/drill or maybe a minimal fee but it is cheaper than replacing batterys constantly. Good luck. Dave
Dec 25, 2008 | Dewalt Drills
Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
Mar 31, 2008 | HP Pavilion dv6000z Notebook
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
