Question about Jensen VM9510 Car DVD Player
VM9311ts Is the media module required for the actual Parking Brake feature to go away? I dont have the Media Module connected at all. Do I need one?
No u dont run the pink wire to a toggle stwich and the other side to a ground and u can run it while u drive
Posted on Oct 02, 2007
Got error 10 and dont know what to do
from REalMacoi your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
1. Turn off the media center via the"ALL OFF" button in the tray (no DVD disc inside the tray)
2. Turn off the bass module by the power switch underneath the bass module (certain versions may not apply)
3. Unplug the power adaptor of the media center and remove the power adaptor connection from the wall socket.
4. Unplug the bass module (if this has not yet been done
5. Disconnect all speaker wires (satellite speakers I mean)
6. Disconnet the data cable linking the bass module and the media center
7. Allow 10seconds to pass
After 10seconds then connect the following again in this sequence
1. Connect the media center and the bass module data cable first
2. Connect the satellite speaker cables.
3. Connect the media center adaptor (DO NOT TURN ON YET!)
4. Lastly connect the bass module power cable (DO NOT TURN ON YET!)
Once verything is connected, press power "ON" button o nthe RF remote and the media center should turn on. Only the you should switch the bass module power "ON" so that a fresh handshake is achieved.
This ERROR 10 occurs when either the ADAPTIQ process is interrrupted, the data calbe link between the bass module and the media center is loose or when the power connection is interrupted.
If all still fails, then there is a problem with the DSP board of the bass module and would require servicing.
I do hope I was able to help you
Sep 21, 2010 | Bose Lifestyle 28 System
Clarion nx700 parking break bypass
Wrong. To bypass the lockout feature so you can see the DVD play anytime - you need to toggle the green wire away from ground (from Low to High - i.e. momentary switch) so the radio sees the rising edge of the 12Vdc signal. The green wire is normally high and is tied low. When you put the parking break on - it opens the loop.
A switch will trigger the Opto Isolator inside the head and bypass the lock out feature. This works fine - or you can spend the $25 on the bypass module - that does the same thing - but works as an electronic toggle ~ based off the remote wire and an internal relay in the module. The module will toggle the green wire every time the radio powers up.
Jul 01, 2010 | Clarion NX700 Car Video Player
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Code 10
Hi, your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
Apr 03, 2009 | Bose Lifestyle 18 System
Is a media link box and media module the same for jensen vm9311ts
they are not the same. the media link will work for that model.
Jan 17, 2009 | Jensen's VM9312 Car DVD Player
How do i bypass parkingbreak for a jensen 9311ts on mustang 99
take the parking brake wire should be pink or some funky color and hook it up to a +12 power source.
that way there is no need to use the e brake or anything for it to work
But as a word of caution all this is illegal in most states due to people not keeping their eyes on the road. ive read of people getting tickets for having disabled this security feature on their stereos. some insurance companys will not cover you if there's an accident you are involved in and you by-passed the safety feature. so before you do it, be sure to read your local laws and check with your insurance agent before doing it. you will not be happy finding things out the hard way.
Dec 02, 2008 | Audiovox VM9311TS
Jensen VM 9311 iPod Classic
You might need the jenson media module,that might have came with it.Mine did and I bought it 2nd hand.and a special ipod cable that hooks from the media module to your ipod.
Mar 16, 2008 | Audiovox VM9311TS
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
Jensen VM9311ts media module
I have the Jensen VM 9311ts. Where can I get a media module for it? I found the cord and the j link cord , but I can't find a media module anywhere. HELP!
Jan 08, 2008 | Jensen VM9411 Car Video Player
Jensen VM9510 Car DVD Player Logo
122 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
